I Electricity and Magnetism: Verifying the Inverse Square Law
  • I
  • Thread starter Thread starter giodude
    Inverse square law
The discussion focuses on verifying the inverse square law using the framework of Purcell and Morin's Electricity and Magnetism textbook. The problem involves calculating the electric field, ##\vec{E}(\vec{r})##, from a static point charge ##Q## located at the origin, utilizing spherical symmetry. By applying Gauss's Law, the radial component of the electric field is derived as ##E_r(r) = \frac{Q}{4 \pi \epsilon_0 r^2}##, confirming the inverse square relationship. The complexity of the problem is acknowledged, attributed to the authors' pedagogical approach. The conclusion emphasizes that the verification hinges on the principles of spherical symmetry and Gauss's Law.
giodude
Hello,
I'm currently working through Purcell and Morin, Electricity and Magnetism textbook and came across a problem in which the goal is to verify the inverse square law. I'm worked through and completed the problem. However, I'm confused how this verifies the inverse square law, I'm posting the images of the solution below.
The attached files are not in .pdf format.
How were they produced ?
I took images of them on my phone and then airdropped them to my laptop, I'll fix them up when I get back to my laptop and edit the post. Thank you.
I've here the 3rd edition, where it seems that the authors try to derive the Coulomb field of a static point charge. As to be expected from this book, it's all buried in some strange pedagogics, making the problem more complicated than it is.
The idea is simply to use the spherical symmetry of the problem. So let the point charge, ##Q##, sit at rest in the origin of a Cartesian coordinate system. We want to calculate ##\vec{E}(\vec{r})## at any position ##\vec{r} \neq \vec{0}##, because at the origin we have obviously a singularity, which is characteristic for the assumption of a "point charge" in classical field theory.
Mathematically the problem is simple because of spherical symmetry. There's no other vector in the problem than ##\vec{r}##, because no direction is in any way special except the direction of the position vector itself. Thus you can make the Ansatz
$$\vec{E} = E_r \vec{e}_r,$$
where ##\vec{e}_r=\vec{r}/r##. The "radial component" ##E_r## can only depend on ##r=|\vec{r}|##, again due to the spherical symmetry.
Now you simply use Gauss's Law in integral form
$$\int_{\partial V} \mathrm{d}^2 \vec{f} \cdot \vec{E}=Q_V/\epsilon_0.$$
It's obvious, again because of the spherical symmetry, to choose a spherical shell of radius ##r## around the origin for ##\partial V##. The surface-normal vectors are ##\vec{e}_r## and thus with our ansatz for ##\vec{E}##
$$E_r (r) 4 \ pi r^2=Q/\epsilon_0 \; \Rightarrow \; E_r(r)=\frac{Q}{4 \pi \epsilon_0 r^2}.$$
That's it! It's simply spherical symmetry and Gauss's Law!
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
