Understanding Electric Field and Charge Distribution Problems
  • Thread starter loki4000
In summary, Andrey is seeking help with a problem in electricity and magnetism. He is looking for a clarification on what the problem is asking him to do and some relevant materials to help him solve it. The problem involves finding the electric field at a point due to a charge and eventually finding the formula for the electric field due to an infinitely long wire. Andrey is also asking about the direction and meaning of dE and where he can find the formula for an infinitely long wire.
loki4000
Hi, I was given following problem to solve
Now, I am not looking for solution, but i would appreciate if someone explain what exactly they are asking me to do (is this about finding final charge vector? or is this about gaussian surface, I am new at electricity and magnetism so I am pretty confused about this problem) and give me some revision materials relevant for this problem (or even better, examples on how to solve similar problems)
Best regards.
Andrey.
Welcome to PF!
I can't help much until you show your work, but I should be able to get you started.
It is not a Gaussian problem. Just an E = kqQ/d² one. Part 1 asks you to find the dE at M due to a charge dq at P. No work needed; just write the answer. Of course it will be all symbols since you aren't given numbers for any of the quantities.
Ultimately, in part 6, you will find the formula for the E field at M due to the charge on an infinitely long wire. You can look that up if you like to know where you are heading in advance.
This is a very useful technique and an important problem; I hope you enjoy it!
By the way, if you need some symbols like ² or λ (often used for the charge/meter density along a line charge), you can copy and paste from
https://www.physicsforums.com/blog.php?b=346
I have a few in my signature, too.
If you have a diagram to show, the best way is to upload it to one of the free photo sites (I use photobucket.com), then paste an IMG link into your post here.
Darn, I made a mistake and the forum isn't showing me the usual edit button!
Of course there should be only one Q in the formula I wrote for E.
Thax for reply,
so, all I need to do is to find final vector considering both positive and negative charge of segment? In that case I assume that charge vector should point directly downwardat point x, is that correct?
Also, dE mean electric field vith certain direction (vector) and not derivative? It may sound like stupid question but I really just started on electricity.
Also, about formula for infinitely long wire, where do I supposed to find it?
Best regards.
Andrey.
It doesn't say anything about two charges of opposite sign. "Uniform charge density" implies the same charge below OM as above, so the E field at M will be horizontal.
dE is an infinitesimal bit of electric field. Start with a dE = f(y)*dy, change variable y to theta and integrate dE to get E.
Google it if your text doesn't have it.
FAQ: Understanding Electric Field and Charge Distribution Problems
What is electricity and how is it related to magnetism?
Electricity and magnetism are two closely related phenomena. Electricity is the flow of electric charge, while magnetism is the property of certain materials to attract or repel other materials. These two forces are interconnected through electromagnetic fields, which are created by moving electric charges and can also affect the motion of electric charges.
How does electricity flow through a circuit?
Electricity flows through a circuit when a voltage source, such as a battery, creates a potential difference that pushes electrons through a conductive material, such as a wire. This movement of electrons is called an electric current. The circuit must also include a complete path for the electrons to flow back to the voltage source.
3. What is the difference between AC and DC electricity?
AC (alternating current) and DC (direct current) are two types of electricity. In AC, the direction of the current changes periodically, whereas in DC, the current flows in only one direction. AC is commonly used for large-scale power distribution, while DC is used in smaller devices and electronics.
4. How do magnets work?
Magnets work by producing a magnetic field, which is a region of space where magnetic forces are exerted. This magnetic field is created by the alignment of the magnetic domains in a material, such as iron or nickel. When two magnets are brought close together, their magnetic fields interact, causing attraction or repulsion between the two objects.
5. What are some practical applications of electricity and magnetism?
Electricity and magnetism have numerous practical applications in our daily lives. Some examples include the use of electric motors in appliances and vehicles, the generation of electricity through power plants, the use of magnets in speakers and headphones, and the use of electromagnetic waves in communication technology.
