Electricity: series and parallel circuit
In summary, the students set up a simple series circuit using three light bulbs and measured the current at each end with an ammeter. The results showed a fluctuation in current, which is not expected in a series circuit where the current should remain constant. The instructor suggests checking for sources of error, such as using a voltmeter in current measurement mode with non-negligible internal resistance. They also discuss similar issues with the voltage measurements in a parallel circuit and suggest using a simple dry cell as a power source for the experiment. Finally, the students realize they may have connected the ammeter incorrectly and the instructor explains how the series resistance of an ammeter can alter the overall current in a circuit.
jnimagine
178
I have a question about series and parallel circuits
We made a simple series circuit using three light bulbs
when we measured the current with the ammeter at each end of the light bulb, they were 30mA at the source, then it began to change to 40,40,60,60,1.6, and 2.3 Do you think this result is right? aren't they all supposed to stay the same??
also, we made a simple parallel circuit using three light bulbs
we measured the voltage at each end of the light bulbs to find the potential difference. Here, too aren't the numbers supposed to stay the same throughtout the whole circuit? My results were 0, 0, 2, -2(?), 2.1, and 2.2
You intuition is correct, so there must have been some problem with the meter or the experiment. The current in a series circuit is the same, and the voltage across parallel elements is the same.
Take a look back at how the measurements were made, and look for sources of error. For example, remember that a voltmeter in current measurement mode has an internal resistance which is not always negligible. When you measure currents in the mA range, the resistance can be many Ohms.
And on the voltage measurements, it looks to be a combination of bad connections (0V) where something wasn't making good contact, and one case of reversed leads (-2V).
Then we probably did the experiment wrong or somethin eh?
but about the 'internal resistance that's not negligible', does this mean the current can fluctuate even in series circuit?? but even with that, it wouldn't fluctuate this much right...? - -;; ------> 30, 40,40,60,60,1.6, and 2.3mA
Did you connect the ammeter in series or in parallel ? The former is the right arrangement.
Also what sort of a voltage source are you using ?
Did something smoke ?
:biggrin:
well we connected the ammeter parallel to the series circuit
and I'm not sure what the name of our voltage source is called but it was just some kind of a power source that u could turn on and off...:confused:
:biggrin:
:rolleyes: uhhh no nothing smoked. . .
Ammeters are supposed to be connected in series along with the other circuit elements so that they can read of the entire series current.
Also, have you tried changing the power source to check ? You could use a simple dry cell for the experiment.
The series resistance of an ammeter (or voltmeter in current measurement mode) can alter the overall current in the circuit, compared to when the meter is not in the circuit. But the current will not fluctuate depending on where the ammeter is placed in a series circuit. Take the example where a series circuit consists of three 1 Ohm resistors, and the series resistance of the meter is 1 Ohm also. If the meter is not in the circuit and you connect up a 3V power supply (I'm just using round numbers here for illustration), then you get 1A of series current through the three resistors. But if you break the connection between either pair of resistors and insert the ammeter, now the total resistance of the series circuit is 4 Ohms, and you get less than the 1A of series current. The insertion of the meter has altered the current in the circuit, but it doesn't matter where in the circuit you insert that extra 1 Ohm of resistance, you will still get the same (altered) current.
Make sense?
FAQ: Electricity: series and parallel circuit
What is the difference between a series and parallel circuit?
A series circuit is a circuit in which the components are connected one after another, forming a single path for the current to flow. In a parallel circuit, the components are connected side by side, providing multiple paths for the current to flow.
How does the voltage and current change in a series and parallel circuit?
In a series circuit, the voltage is divided among the components, resulting in a decrease in voltage as the current flows through each component. In a parallel circuit, the voltage across each component remains the same, while the total current is divided among the components.
Which circuit is better for powering multiple devices?
A parallel circuit is usually better for powering multiple devices as each device receives the full voltage and can operate independently. In a series circuit, if one device fails, the entire circuit will be disrupted.
How do you calculate the total resistance in a series and parallel circuit?
In a series circuit, the total resistance is the sum of the individual resistances. In a parallel circuit, the reciprocal of the total resistance is equal to the sum of the reciprocals of each individual resistance. This can also be calculated using Ohm's law: R = V/I, where R is the resistance, V is the voltage, and I is the current.
What are some real-life examples of series and parallel circuits?
A common example of a series circuit is a string of Christmas lights, where the bulbs are connected one after another. A parallel circuit can be seen in a household electrical outlet, where multiple devices can be plugged in and operate independently at the same time.
