Electrochemistry: rate constant dependence on CV peak
In summary: I can't say for sure, but it might be related to the diffusion limitation of the electrolyte. For example, if the diffusion limited system is a microemulsion, then the peak current might be lower because the current is limited by the diffusion of the electron-rich species to the electrode surface.
MatthiasS
Hi there,
I am currently studying charge transfer reactions between metallic electrodes and redox couples in aqueous electrolytes (in a diffusion limited system), and I was wondering about the influence of the rate constant on the reduction/oxidation peak maximum. Typically, it is assumed that a decreasing rate constant results in a greater reduction/oxidation peak separation and also in a reduction of the peak current values (see attached picture). I get why the peak separation increases for slower rate constants, but I do not understand what causes the decrease of the peak maximum (since the diffusion of the electroactive species in the electrolyte should limit the maximum current value). Does anybody have an idea what causes the decreasing peak currents?
Thanks a lot for your help!
Cheers,
Matthias
Chemistry news on Phys.org
I'm not an electrochemist, but I don't think the electron transfer rate constant would say anything about peak separation between red/ox in the microscopic level. The redox potential of a molecule and an electrode is a fixed parameter in absence of external potential. If I were to say anything about rate constant and redox potential, I would probably talk about it the other way around. It is the applied potential that causes change in rate constant.
When you apply voltage to an electrochemical cell, the redox potential of the electrode changes depending on the applied voltage. This allows electron transfer TO the molecule when electrode potential is low enough relative to the molecule's reduction potential, and electron transfer FROM the molecule when the electrode potential is high enough relative to the molecule's oxidation potential. The rate constant itself corresponds to such "potential matching" (I don't know the technical term for this) and electron correlation between the molecule and the electrode. Typically, electron correlation between a molecule and electrode remains the same unless the molecule as a specie changes its property (e.g. after reduction or oxidation). In the particular case of the OP, I would assume that for all measurements, same molecule/electrode combination is used. In another words, it is not the rate constant that changes the CV, but the applied voltage. It is quite awkward when you say "changing the rate constant".Under this in mind, if you are talking about changing the molecule/electrode combination under hypothetical situation where these species have same red/ox potential but have different electron correlation, then I think we will be discussing whether the experimental conditions of CV are appropriate or not. In the case where the CV scan speed is too fast, if:
1) electron correlation is large, then the electron transfer rate between molecule and electrode is fast enough that the CV curve shows the true red/ox potential of the molecule.
2) electron correlation is small, then the electron transfer rate between molecule and electrode is too slow that it cannot catch up to the speed of applied voltage. I think in such case, the CV peaks will be separated than it is supposed to, with much broader peak.
Is this what you are talking about?
Likes MatthiasS
Observed - yes. Absolute - no. Matter of a point of view.
Well you are right, but from the OP I had no other way to interpret the question.
Thanks aa lot for your answer!
Yes, I was thinking about a hypothetical situation in which we have the same red/ox potential, but different rate constants.
The reason for my question is that I am interested on how a thin surface layer (sufficiently thin to allow for electron tunneling) affects peak separation and peak current of the CV curves. Typically, depending on the thickness of the surface layer, this layer is expected to decrease the rate constant (as far as I know this effect is even used to investigate the charge transfer kinetics of very fast reactions which would otherwise be difficult to measure due to diffusion limitations).
When I checked the literature on CV measurements in presence of thin surface layers, it seems that typically (i) the peak separation increases and (ii) the peak current density decreases (compared to the unmodified electrode). I agree that for slow scan rates the electron transfer rate between molecule and electrode might be too slow to catch up to the speed of the applied voltage (which results in an increased peak separation), but I do not understand why this also affects the peak current density (since the peak current density should depend only on scan rate as well as on concentration and diffusion coefficient of the redox couple).
I can be wrong, but judging from what is written in Theoretical Principles of Electrochemical Analysis (by Z. Galus, unfortunately I have it only in Polish), lower peaks are already predicted by the theoretical solutions given by Matsuda and Ayabe in Z. Electrochem, 59, 494 (1955).
http://onlinelibrary.wiley.com/doi/10.1002/bbpc.19550590605/abstract
When I checked the literature on CV measurements in presence of thin surface layers, it seems that typically (i) the peak separation increases and (ii) the peak current density decreases (compared to the unmodified electrode). I agree that for fast scan rates the electron transfer rate between molecule and electrode might be too slow to catch up to the speed of the applied voltage (which results in an increased peak separation), but I do not understand why this also affects the peak current density (since the peak current density should depend only on scan rate as well as on concentration and diffusion coefficient of the redox couple).
I don't understand what you are saying. You've just answered your own question.
Related to Electrochemistry: rate constant dependence on CV peak
1. How does the rate constant affect the CV peak in electrochemistry?
The rate constant is a measure of how quickly a reaction occurs. In electrochemistry, it determines the speed at which electrons are transferred between the electrode and the electrolyte. A higher rate constant leads to a sharper and taller CV peak, indicating a faster reaction rate.
2. What factors influence the rate constant in electrochemistry?
The rate constant is affected by several factors, including the nature of the reactants, temperature, and the presence of any catalysts. It also depends on the electrode material and the properties of the electrolyte solution, such as its concentration and pH.
3. How can the rate constant be determined experimentally?
The rate constant can be calculated by analyzing the shape and size of the CV peak using techniques such as cyclic voltammetry or chronoamperometry. These experiments involve varying the potential or current and measuring the resulting changes in the CV peak.
4. What is the significance of understanding the rate constant in electrochemistry?
The rate constant is a crucial parameter in electrochemistry as it provides information about the kinetics of a reaction. It can help in predicting the behavior of a system and optimizing reaction conditions for desired outcomes. Additionally, it can provide insights into the mechanism of the electrochemical reaction.
5. How does the rate constant affect the overall efficiency of an electrochemical reaction?
The rate constant directly influences the reaction rate, which, in turn, affects the efficiency of the electrochemical process. A higher rate constant results in a faster reaction rate, leading to a more efficient conversion of reactants into products. Therefore, understanding and optimizing the rate constant is crucial for improving the efficiency of electrochemical reactions.
  • Materials and Chemical Engineering
  • Poll
  • Science and Math Textbooks
