- #36
sdefresco
- 29
- 1
Conductors have always spun me in circles intuitively. So, |Egap|=|σ1|/εo=|σ2|/εo, if I'm correct. This could be concluded using the boundary condition that ΔE=σ/εo when crossing a surface, or by using Gauss' Law.Delta2 said:Given that s<<R we can make the approximation that all σiσi will be constant throughout their respective domains. Also that the two spherical caps each carry charge +Q/2 since the whole system is very similar to an uncut sphere (because s<<R). This leaves that the flat face of the upper hemisphere (to which we put total charge +Q) has charge +Q/2 and the flat face of the lower hemisphere has charge -Q/2. Again because s<<R the electric field due to the charges on the flat surfaces will be zero in the space that is not in-between the flat surfaces. The electric field in-between the flat surfaces will be that of a parallel plate capacitor with charge Q/2 and -Q/2 in each plate.
I think with the guide of @TSny the problem has been solved, you just haven't realized it :D.
Also, σ1=Qeff/A=(1/2)Q/(πR2).
