Electrodynamics without fields?
In summary, the Heaviside-Feynman formula is not an action-at-a-distance theory. It describes a "retarded" direct interaction between charges that only propagates at the speed of light.
johne1618
371
Can one describe electrodynamics without any reference to fields?
I think you can.
Using the Heaviside-Feynman expression for the electromagnetic field due to an arbitrarily moving charge, together with the Lorentz force law, one can write down an expression for the electromagnetic force [itex]\mathbf{F}[/itex] on a charge [itex]q_1[/itex], that is instantaneously at rest in an inertial frame, due to an arbitrarily moving charge [itex]q_2[/itex] as:
[tex]
\mathbf{F} = \frac{q_1 q_2}{4 \pi \varepsilon_0} \left\{ \left[ \frac{\mathbf{\hat{r}}}{r^2} \right]_{ret} + \frac{\left[ r \right]_{ret}}{c} \frac{\partial}{\partial t}\left[\frac{\mathbf{\hat r}}{r^2}\right]_{ret} + \frac{1}{c^2} \frac{\partial^2 \left[ \mathbf{\hat r} \right]_{ret}}{\partial t^2} \right\} \\
[/tex]
where [itex][\mathbf{r}]_{ret}[/itex] is the vector from the retarded position of [itex]q_2[/itex], at time [itex]t - [r]_{ret}/c[/itex], to [itex]q_1[/itex], at time [itex]t[/itex].
Does the above formula contain all of classical electromagnetism?
In principle, one could use directly only the EM forces between the charged particles and then solve all the equations of motion. However, they are not given by the formula you wrote exactly - one should use the forces that are given by fields that are solutions of Maxwell's equations. You can find them in the book by Jackson or Landau&Lifgarbagez.
The problem with these formulae is that they are not unique - there are many formulae that give different forces but still are consistent with Maxwell's equations. Usually, however, the retarded form of the fields is assumed.
However, in macroscopic theory, one deals with enormous number of particles and it is much more tractable to use macroscopic fields. For example, the wave equation for medium can explain many things with fields - doing the same with the formula for retarded force is possible, but also much more difficult.
Do you mean the Electric and Magnetic field solutions of the Liénard–Wiechert potentials given in :
http://en.wikipedia.org/wiki/Liénard–Wiechert_potential ?
As far as I know the Heaviside-Feynman expression for the fields of a point charge is completely equivalent to the Liénard–Wiechert fields. Jackson on page 247,248 of his book derives the Heaviside-Feynman formula from Jefimenko's equations. He doesn't suggest that the Heaviside-Feynman formula is approximate.
yes,of course.The formula you use in the expression of force is for only electric force.You can also write the formula for magnetic field also.They are just the generalized form of coulomb and biot-savart law.They hold for arbitrary motion of charge.It is very general.It is not approximate.
if you want to describe electrodynamics as a theory in which action at a distance can be eliminated by the principle of locality(which holds for almost all physical accepted theories) then you will have to go with the field concept.
True.
But I can always eliminate the need for a magnetic field by using an inertial frame in which the receiving charge is at rest.
As far as I understand the Heaviside-Feynman formula is not an action-at-a-distance theory. It describes a "retarded" direct interaction between charges that only propagates at the speed of light.
The fundamental problem here is that after you write up and solve the equations of motion for the charges, you will find the charges accelerating. The conventional particle-field description predicts loss of particle energy & momentum through radiation. So the equations of motion would seem to violate energy/momemtum conservation.
Folks, please look at the PF Rules again. "Here is my idea, prove me wrong" is not acceptable here. Based on other postings, it looks like a back door into highly speculative posts. We're not going down this path.
While it is possible to write something like this, it is useless. As the OP himself said, explaining magnetism requires one to calculate in an infinite number of continually changing frames. Light, as a separate phenomenon, does not exist, and if you want to have energy conservation, you need to impose a virtual absorber for the light at infinity. It misses a large chunk of the physics - for example, the response of a particle to identical fields produced by different charge configurations is identical.
This is useless.
FAQ: Electrodynamics without fields?
What is "Electrodynamics without fields"?
"Electrodynamics without fields" is a theoretical framework in electromagnetism that describes the behavior of electric and magnetic forces without the use of traditional fields. Instead, it uses the concept of charge and current densities to explain the interactions between charged particles.
How is "Electrodynamics without fields" different from traditional electrodynamics?
In traditional electrodynamics, the behavior of electric and magnetic forces is described using the concept of fields, which are quantities that exist in space and can be measured at different points. "Electrodynamics without fields" does not use this concept and instead focuses on the distribution of charges and currents to explain the behavior of electric and magnetic forces.
What are some practical applications of "Electrodynamics without fields"?
"Electrodynamics without fields" has been applied in various fields of physics, such as quantum mechanics, condensed matter physics, and particle physics. It has also been used to study the behavior of materials and devices at the nanoscale, as well as to understand the dynamics of plasmas and other complex systems.
Can "Electrodynamics without fields" fully replace traditional electrodynamics?
No, "Electrodynamics without fields" is not intended to replace traditional electrodynamics. While it offers a different perspective and has its own set of advantages, it is still a theoretical framework and cannot fully capture all the complexities of electromagnetism.
Are there any controversies surrounding "Electrodynamics without fields"?
There is ongoing debate and discussion among scientists about the validity and usefulness of "Electrodynamics without fields". Some argue that it offers a more fundamental and intuitive understanding of electromagnetism, while others argue that it is limited in its applicability and does not fully explain all phenomena in the same way as traditional electrodynamics.
