Electrolysis and electroplating electrolytes and oxidation states
In summary, copper will form cations and the OH- will be oxidized in the first scenario, A and B are both oxidized and reduced in the second scenario, and A and D are oxidized while B and C are reduced in the third scenario.
sgstudent
739
When electrplating copper with a dilute NaCl aqueous solution and the anode is iron while cathode is platinum what will the results be? Will copper form cations or will the OH- be oxidised? Also, if we use concentrated NaCl will there be any difference? I'm thinking that the copper shouldn't be able to oxidised as it should not be able to exist as ions alone? So only the Cl-/OH- should oxidise. But if the copper is replaced with zinc then it could happen as at the cathode, H+ ions will be reduced. So the Zn2+ ions will always have an anion to have an equilibrium. But for the copper case, there is nothing to fill up the equilibrium as in there us no anion "counterpart" to it. But I'm not very sure about this.
When a reaction AB-->BA at the reactants side A oxidation: +1 B is -1 at product A:-1 B:+1 is AB both oxidised and reduced?
When a reaction AB+CD-->AD+CB and reactants oxidation A:+1 B:-1 C:+1 D:-1 while at the products side A:+2 D:-2 C:+2 B:-2
What is oxidised and what is reduced?
Thanks for help guys!
Chemistry news on Phys.org
In the first scenario, copper will form cations, and the OH- will be oxidized. If a concentrated NaCl solution is used, the reaction rate of the electrolysis will be faster, but the results will still be the same. For the second scenario, A and B are both being oxidized and reduced. This is known as a redox reaction. The oxidation states of A and B change from +1 and -1 respectively, to -1 and +1 respectively. For the third scenario, A and D are both being oxidized, and B and C are both being reduced. A and C are oxidized from +1 to +2, while B and D are reduced from -1 to -2.
Related to Electrolysis and electroplating electrolytes and oxidation states
1. What is electrolysis and how does it work?
Electrolysis is a process in which an electric current is passed through a solution or molten substance, causing a chemical reaction to occur. This reaction involves the transfer of electrons from one substance to another, resulting in the breakdown of the original substance into its component parts.
2. What are some common electrolytes used in electrolysis and electroplating?
Some common electrolytes used in electrolysis and electroplating include aqueous solutions of acids, bases, and salts. These can include sulfuric acid, sodium hydroxide, and various metal salts such as copper sulfate or nickel sulfate.
3. How do oxidation states play a role in electrolysis and electroplating?
Oxidation states, also known as oxidation numbers, indicate the number of electrons that an atom has gained or lost in a chemical reaction. In electrolysis and electroplating, oxidation states are important because they determine which ions will be attracted to the electrodes and which substances will be deposited during the process.
4. Can electrolysis and electroplating be used to purify metals?
Yes, electrolysis and electroplating can be used to purify metals. This is because the process separates the desired metal from impurities by causing it to deposit on the electrode, while the impurities remain in the electrolyte solution.
5. Are there any environmental concerns associated with electrolysis and electroplating?
Yes, there are environmental concerns associated with electrolysis and electroplating. The process can produce hazardous waste, such as heavy metal ions, which can contaminate the surrounding environment if not properly disposed of. Additionally, the energy required to run the process can contribute to carbon emissions and climate change.
  • Chemistry
10K
