Electrolysis of aq CuCl2 with Ag electrode
In summary, the conversation discusses the process of electrolysis using silver electrodes and aq Copper (II) Chloride. The products formed depend on the voltage applied and the cathode and anode used. The question also considers the presence of chlorides in the solution and the concentration of the solution, which can affect the outcome of the experiment.
matthew77ask
45
I have a question on electrolysis:
In the electrolysis of aq Copper (II) Chloride using silver electrodes, what are the products?
Cathode : Copper or silver are deposited here? cos both are in the solution
anode : silver electrode decrease in size... with silver deposits?
Am I correct?
You need to know the voltage applied and you need to know what is the cathode and what is the anode.
Seems like that's a given.
Basically the question can be split in two:
What is the reaction on anode? What are possibilities?
What is the easiest to reduce substance present in the solution, one that will be reduced first?
And don't forget about chlorides presence. Concentration is not given, but it may be not that important, perhaps it will be possible to estimate what is happening without knowing exact numbers.
I misunderstood. TWO ELECTRODES, both Silver.
So if electrolysis will occur, the Cu+2 will become reduced to Cu metal at one particular electrode, and Ag+ will form and go into solution at the other electrode.
Not necessarily. But let's allow OP to answer the question this time.
Cu+2 could be reduced to Cu+1, depending on voltage and conditions of solution; not sure if this is reasonable for electrolysis. Probably is.
it's confusing at the cathode - cos both Ag+ (from the anode) and Cu2+ (from the electrolyte ) are present.
Its more of a simple set up without going into too much details. Its for O level type of question.
Concentration - aqueous solution.
Good attention to detail, there. Yes, if the anode is producing Ag+, then the cathode could be depositing Ag and either plating Cu0 or making Cu+1. My wits stop there.
Honestly - I have no idea what the intended answer is. Remember that silver concentration is limited by the silver chloride solubility in the presence of chlorides from copper chloride. That means it all depends on the concentration of CuCl2. For low concentrations silver dissolves and deposits, Cu2+ is just a spectator. For higher concentrations - copper deposits till its concentration is so low silver starts to deposit. "Aqueous solution" doesn't tell anything about concentration, it can be anything - saturated copper chloride solution is close to 2M, diluting it to 10-5M is five minutes work. Limiting concentration (one that changes the experiment outcome) lies in between.
Related to Electrolysis of aq CuCl2 with Ag electrode
1. What is the purpose of using an Ag electrode in the electrolysis of aq CuCl2?
The Ag electrode is used as the cathode in the electrolysis setup because it is a more reactive metal than copper. This means that it will attract the negatively charged chloride ions and allow the positively charged copper ions to be reduced to solid copper, which will then be deposited on the electrode.
2. How does the concentration of CuCl2 affect the electrolysis process?
The concentration of CuCl2 affects the electrolysis process by determining the number of ions present in the solution. A higher concentration means more ions to be reduced and deposited on the electrode, resulting in a faster and more efficient electrolysis process.
3. Can other electrodes, such as graphite, be used instead of Ag in the electrolysis of CuCl2?
Yes, other electrodes can be used for the electrolysis of CuCl2, but they may not be as effective as the Ag electrode. Graphite, for example, is a relatively unreactive material and may not attract the chloride ions as well as Ag, resulting in a slower and less efficient electrolysis process.
4. What is the purpose of using an electrolyte, such as NaCl, in the CuCl2 electrolysis setup?
The electrolyte, such as NaCl, is added to the CuCl2 solution to increase its conductivity. This allows for a more efficient flow of electricity through the solution, making the electrolysis process faster and more effective.
5. What are some potential applications of the electrolysis of aq CuCl2 with Ag electrode?
The electrolysis of aq CuCl2 with Ag electrode has several potential applications, such as electroplating copper onto surfaces to create a decorative or protective layer, extracting pure copper from its ore, and purifying copper for use in various industries. It can also be used in educational settings to demonstrate the principles of electrolysis and electrochemistry.
