Electromagnet offset between applied voltage and magnetic field intensity
In summary, there are three main sources of offsets in the relationship between applied tension and resulted magnetic field intensity on an electromagnet. These include coil resistance, eddy currents, and hysteresis losses. Coil resistance is independent of frequency, while eddy currents and hysteresis losses are both frequency-dependent. To accurately calculate the phase shift between current and voltage, it is important to consider all three of these factors.
Mekatorque
I'm trying to find a mathematical formula between applied tension and resulted magnetic field intensity on an electromagnet.
I know that between the voltage and the electric current there is a pi/2 offset, but in practice there is a bit more than actually pi/2 offset probably something that has to do with the core material of the electromagnet.
Any ideas are welcomed.
There are three main sources of offsets of the pure imaginary relationship between current and voltage in an electromagnet. In all 3 cases, the phase shift in the frequency domain is θ = atan[ωL/R]:
1) coil resistance R (independent of frequency)
2) eddy currents (like in a laminated electromagnet). Use standard equations for transformer laminations, and coatings. R goes as frequency squared.
3) Hysteresis losses. There is a specific energy loss per cycle, depending on magnetic material, and excitation. You need to multiply the energy loss per cycle by the number of cycles per second, so is linear in frequency. See
http://www.electronics-tutorials.ws/electromagnetism/magnetic-hysteresis.html
Bob S
Related to Electromagnet offset between applied voltage and magnetic field intensity
What is the relationship between applied voltage and magnetic field intensity in an electromagnet?
The strength of the magnetic field produced by an electromagnet is directly proportional to the applied voltage. This means that the higher the applied voltage, the stronger the magnetic field will be.
Why is there an offset between applied voltage and magnetic field intensity in an electromagnet?
The offset between applied voltage and magnetic field intensity is due to factors such as the number of turns in the wire, the material of the core, and the shape and size of the electromagnet. These factors affect the efficiency of the electromagnet and can result in a difference between the applied voltage and the resulting magnetic field intensity.
How can the offset between applied voltage and magnetic field intensity be minimized in an electromagnet?
The offset can be minimized by using a larger number of turns in the wire, using a core made of a highly magnetic material, and optimizing the shape and size of the electromagnet. Additionally, using a higher quality power supply can also help reduce the offset.
What is the unit of measurement for the offset between applied voltage and magnetic field intensity?
The offset between applied voltage and magnetic field intensity is typically measured in units of tesla (T) or gauss (G), which are both units of magnetic field strength.
How does the offset between applied voltage and magnetic field intensity affect the overall performance of an electromagnet?
The offset between applied voltage and magnetic field intensity can affect the overall performance of an electromagnet by decreasing its efficiency and reducing the strength of the magnetic field produced. This can impact the electromagnet's ability to perform its intended function, such as lifting heavy objects or generating electricity.
