Electromagnetic elevation expectations
In summary, an electromagnet can be designed to lift a variable weight up to a certain limit, and it is not cost prohibitive.
Drnwooten
I am wondering the realistic expectation of a large, rectangular electromagnet, or series of them, to elevate a variable weight.
Specifically, can an electromagnet be designed in a 76 inch by 80 inch platform and elevate a plate of the same dimensions that can hold a maximum of 400 pounds?
Secondly, if the design is feasible, would it be cost feasible for the materials?
Thank you so much.
Yes. Actually, it can be much smaller. See the electromagnets used for scrapyards, they are smaller, can lift more, and don't even need a special platform.
What is "feasible" for costs? Different applications will have different limits.
Thanks for your reply.
I need the base to be that specific size though, and to be able to levitate a platform that same size.
Well, it can be smaller. Making it larger makes it easier.
Excellent! That's what I was hoping for.
Thank you very much.
Can you direct me in the way of making this happen? I'm having trouble finding design plans for something like this.
Lifting loads of that size with an electromagnet should be done by equipment built by an expert.
Say you make an electromagnet with an E shape, a total cross section area = 1m2 and a magnetic induction = 1T, it can elevate an iron plate about 41000 kg. ( 74000 pounds ). The force is proportional to the magnetic induction and the cross section area.
So obtain an E shaped iron core and calculate number of turns and required current by means of amperes law. ( Remember about 0.1mm airgaps ).
Don't use higher magnetic induction than 1T, or the iron will saturate. Calculate it to elevate 400 pounds+30%.
Keep your feets at some distance during test. :wink:
FAQ: Electromagnetic elevation expectations
What is electromagnetic elevation?
Electromagnetic elevation refers to the process of raising an object or material using electromagnetic forces. This can be achieved through the use of electromagnets, which create a magnetic field that can attract or repel other objects.
How does electromagnetic elevation work?
Electromagnetic elevation works by utilizing the principles of electromagnetism. An electric current is passed through a wire, which creates a magnetic field around the wire. By varying the strength and direction of the current, the magnetic field can be used to attract or repel other objects, thereby lifting them up.
What are some applications of electromagnetic elevation?
Electromagnetic elevation has various applications in industries such as manufacturing, transportation, and healthcare. It can be used to lift and move heavy objects, levitate trains for high-speed transportation, and even in medical procedures like magnetic levitation for drug delivery.
Are there any limitations to electromagnetic elevation?
Yes, there are some limitations to electromagnetic elevation. The strength of the magnetic field decreases with distance, so the object being lifted must be within a certain range. Additionally, the weight of the object being lifted must not exceed the maximum weight that the electromagnet can support.
Can electromagnetic elevation be dangerous?
Like any other scientific technology, electromagnetic elevation can be dangerous if not used properly. The strong magnetic fields can affect electronic devices and cause harm to individuals with pacemakers or other medical devices. It is important to follow safety protocols and guidelines when working with electromagnets for elevation purposes.
