[Electromagnetic Fields] Electrical conductivity of a material
In summary: Since we know the values of V, r, ρ, L, and d, we can plug them into this equation to get the conductance per metre.In summary, to find the conductance per metre between the two wires in an infinite medium of conductivity 2 Sm^-1, we use the equations J = σE, E = V/d, V = IR, R = ρL/πr^2, and G = J/σ. After substituting and simplifying, we get G = (Vπr^2)/(ρLd). We can then plug in the values for V, r, ρ, L, and d to calculate the conductance per metre. The correct answer is option D
MrPacane
Two inflnitely long, straight, parallel Wires are embedded in an infmite medium of conductivity 2 Sm-1. The wires are identical, with a round cross-section of radius 0.25 cm. The centres of the wires are 1 cm apart. Find the conductance per metre between the wires.
A) 0.76 Sm-1
B) 1.19 Sm-1
C) 3.05 Sm-1
D) 4.77 Sm-1
J = σE
∫D∙ds = ∫ρdv = Q or ∇∙D = ρ
D = εE
I have no idea where to start from :( ...
Dear student,
Thank you for your question. I am happy to help you with your problem.
To solve this problem, we will use the equations you have listed. First, we need to find the electric field between the two wires. Since they are infinitely long and parallel, the electric field will be constant and directed towards each other. We can use the formula for the electric field between two parallel plates, which is E = V/d, where V is the potential difference and d is the distance between the plates.
In this case, the potential difference between the wires is the same, and we can calculate it using Ohm's law: V = IR, where I is the current and R is the resistance. We know that the resistance of each wire is given by R = ρL/A, where ρ is the resistivity, L is the length, and A is the cross-sectional area. Since the wires are identical, we can simplify this to R = ρL/πr^2, where r is the radius of the wire.
Now, we can substitute this into our equation for the potential difference: V = (IρL)/(πr^2). Since the wires are in an infinite medium, we can assume that the current is the same in both wires, and we can calculate it using Ohm's law again: I = V/R = (Vπr^2)/ρL.
Finally, we can substitute this into our equation for the electric field: E = V/d = [(Vπr^2)/ρL]/d = (Vπr^2)/(ρLd). This gives us the electric field between the wires.
Next, we can use the equation J = σE to calculate the current density between the wires. Since the wires are in an infinite medium, we can assume that the current density is the same throughout the medium. Substituting our calculated electric field and the given conductivity of 2 Sm^-1, we get J = (2 Sm^-1)(Vπr^2)/(ρLd).
Finally, we can calculate the conductance per metre between the wires using the equation G = I/V = J/σ. Substituting our calculated current density and the given conductivity, we get G = [(2 Sm^-1)(Vπr^2)/(ρLd)]/2 Sm^-1 = (Vπr^2)/(ρLd).
Related to [Electromagnetic Fields] Electrical conductivity of a material
1. What is electrical conductivity?
Electrical conductivity is a measure of how well a material can conduct electricity. It is the ability of a material to allow the flow of electric charge through it.
2. How is electrical conductivity measured?
Electrical conductivity is measured in siemens per meter (S/m) or mhos per meter (mho/m), which is the inverse of electrical resistance. It can also be measured in units of ohm-centimeters (Ω·cm) or ohm-meters (Ω·m).
3. What factors affect the electrical conductivity of a material?
The electrical conductivity of a material is affected by several factors, including the type and number of free electrons in the material, the temperature, and the presence of impurities or defects in the material's structure.
4. How does temperature affect electrical conductivity?
In most materials, as the temperature increases, the electrical conductivity also increases. This is because at higher temperatures, more electrons are able to break free from their atoms and move freely, increasing the flow of electric charge through the material.
5. What are some examples of highly conductive materials?
Some examples of highly conductive materials include metals, such as copper, gold, and silver, as well as superconductors, which have zero electrical resistance at extremely low temperatures. Other materials, such as graphite and saline solutions, also have relatively high electrical conductivity.
  • Electromagnetism
