FS98
- 105
- 4
[/B]
(a) At each corner of a square is a particle with charge q. Fixed at
the center of the square is a point charge of opposite sign, of magnitude Q. What value must Q have to make the total force on each of the four particles zero?
(b) With Q taking on the value you just found, show that the potential energy of the system is zero, consistent with the result from Problem 1.6.
[/B]
F = kq1q2/r^2
For part a, I set up the square with 4 particles at the corners and 1 particle at the center. I then set the x-axis to be along the line connecting three of the particles. After that I went on to find all of the forces acting on one of th corner particles by all other corner particles. The y compenents of all forces cancel out. For the x component, I found that for the two closer particles there was a force of kq^2/r^2 and for the farther particle there was a force of 1/4 of that because the value for r is twice as great. Setting the magnitude this force equal to the magnitude of the force applied by the particle in the center I got the answer Q = 9/4q.
Now for the second part I’m not quite sure what to do. I found the equation U = kqQ/r for the potential energy of two particles, but I’m not quite sure what to do with there being 5 particles.
