magnetic-man
- 19
Whats the easiest way to test the max output of electricity induced in an air coil.
I will wire it 3 phase delta. (or double delta) Will I need a resistive load attached for current flow? What should I use? How do I test? Use a multi tester? Is there math I can use to estimate the amount. I tried E = B times v times l. Flux in Tesla, velocity in M/s and l in meters. So E = 23.4T X 37.5 M/s x 675M =86,062.5 Volts? How do get amps? I want maximum amps. Is there a trick? This is not hypothetical. I've built this generator. I 'd like to get 550 volts at 100 amps. Possible? Any help would be great. Thanks Magnetic-man
