JosephF
- 14
Apologies for numerous posts today, I'm trying to catch up from work I missed last term, and my uni is on holiday at the moment so can't get help from lecturers.
I've been set the following which I think I've got correct, but not 100%. Am I right in calculating the area in m2?
2. A rectangular coil measuring 20mm by 35mm and having 650 turns is rotating about a horizontal axis which is at right angles to a uniform magnetic field of flux density 2.5x10-3T. The plane of the coil makes an angle θ with the vertical, as shown in the diagrams.
(i) State the value of θ when the magnetic flux through the coil is a minimum.
(ii) Calculate the magnetic flux passing through the coil when θ is 30o.
(iii) What is the maximum flux linkage through the coil as it rotates?
ΔΦ=NBAsinθ
i) Φ is at a minimum when θ=0
ii) ΔΦ=650x(2.5x10-3)x(0.002x0.0035)sin30
=1.365x10-5sin30
=5.6875x10-6Wb
iii) Flux linkage is maximum when θ=90
ΔΦ=1.375x10-5sin90
=1.375x10-5Wb
Thanks,
ΔΦ=NBAsinθ
=1.365x10-5sin30
=5.6875x10-6Wb
ΔΦ=1.375x10-5sin90
=1.375x10-5Wb
Thanks,
