Electromagnetic Induction Project Help
In summary: NEW-AUTO- TRANSFORMER-240-V-50-HZ-Single-Phase-1-1-HP-/251992690196?pt=UK_Home_Gardening&hash=item3a80f022c2
Jimmy87
686
Hi, trying to http://physics.stackexchange.com/questions/189766/teslas-egg-of-columbus# Tesla's egg of Columbus for a science project ().
I have managed to cast a small rod of solid aluminium into a solid egg shaped piece of aluminium. I also have a large glass bowl that could sit inside an induction stator. However, I am unsure about how to get the correct induction stator for this to http://physics.stackexchange.com/questions/189766/teslas-egg-of-columbus# . Does it have to be 3 phase? Or could I, for example, http://physics.stackexchange.com/questions/189766/teslas-egg-of-columbus# this single phase induction motor (http://www.ebay.co.uk/itm/Newmans-induction-single-phase-motor-Made-in-England-/251995671260?pt=LH_DefaultDomain_3&hash=item3aac1ccadc) and take the motor out and sit the glass bowl inside with the egg on http://physics.stackexchange.com/questions/189766/teslas-egg-of-columbus# and then plug it into the mains? My worry is plugging the stator into a wall socket, will this be safe?
Any help on how to go about this would be great!
What's the purpose? To make the egg spin?
With a single phase you will not have any rotational movement of the magnetic field. It will just go back and forth. With three phases ( or two ) the magnetic field will rotate because you are making a current-triangle ( an area ) wherein there is "space" for an angle and thus for an angular velocity. You cannot draw an angle within a line ( except for a fixed angle of 0 or 180° ). No space for an angular velocity.
Your single phase motor will turn because a pseudo-phase is created by means af an extra coil in series with a capacitor. This capacitor will make a current phaseshift in the extra coil, thereby making the space.
Use a safety transformer with a secondary voltage of say 32V. ( I don't know what "safety" is in US. ).
Hi, thanks for the info. Yeh purpose is to make the egg spin. Will I need a 3 phase stator then and connect it to a variac or something?
Yes, but remember that variacs are often made with only one coil, acting as both primary and secondary coil. It's a auto-transformer that does not separate the grid voltage from the secondary voltage. It is just stepping up/down the grid voltage. Use an ohm-meter to test if there is connection between the primary voltage is isolated from the secondary voltage (safety). Auto transformer:
Related to Electromagnetic Induction Project Help
1. What is electromagnetic induction?
Electromagnetic induction is the process by which a changing magnetic field produces an electric field and induces an electric current in a conductor.
2. How does electromagnetic induction work?
Electromagnetic induction works by moving a magnet or changing the magnetic field near a conductor, which creates a flux of magnetic field lines that cut through the conductor and induce a current.
3. What are some real-life applications of electromagnetic induction?
Some real-life applications of electromagnetic induction include generators, transformers, electric motors, and wireless charging devices.
4. What factors affect the amount of induced current in a conductor?
The amount of induced current in a conductor depends on the strength of the magnetic field, the speed of the relative motion between the magnet and conductor, and the angle at which the conductor cuts through the magnetic field lines.
5. How is electromagnetic induction related to Faraday's law?
Faraday's law states that the magnitude of the induced electromotive force (EMF) in a circuit is directly proportional to the rate of change of the magnetic flux through the circuit. This is the principle behind electromagnetic induction.
  • Mechanical Engineering
