Electromagnetic Induction Question
In summary, a helicopter has 4 rotor blades that are 5.2m long and spin at 6 revolutions per second. The Earth's magnetic field of 0.047T induces an emf of 0.048V at the tip of the rotor blade. There was a discussion about using the area of the entire circular path instead of just the blade and the possibility of a changing flux through the closed path's surface. However, it was determined that the answer is likely zero due to the material of the helicopter blades and the fact that the speed used in calculations should be divided by 2 to account for the average speed of the blade.
Erwin Schrodinger
24
A helicopter has 4 rotor blades attached to the central axis of rotation. (Like a + sign with the axis of rotation at the center.)
Each rotor blade is 5.2m long and spins at 6 revolutions per second perpendicular to the Earth's magnetic field of 0.047T. What is the emf induced between the axis and the tip of a rotor blade?
This is what I did.
The tip of a rotor blade sweeps out a circular path so:
v = 2πr/T = 2πrf = 2π(5.2)(6) = 196.035m/s
emf = Blv = 0.047(5.2)(196.035) = 0.048V
A friend of mine had this solution.
Φ = BA = 0.047π(5.2)^2 = 0.004Wb
emf = -N∆Φ/∆t = -N∆Φf = -1(0.004)(6) = 0.024V
I told him his solution didn't work because he is using the area of the entire circular path instead of the area of the blade (which cannot be calculated by the way). Also he is using the initial flux as the change in flux which isn't correct either. So who is right? Or are we both wrong?
To get a net EMF from the line integral around a closed path, the amount of magnetic flux through the closed path's surface has to be changing. I don't get how you have a changing flux with this geometry... Am I missing it? Now if you had a single magnet that each blade was passing over, then sure, the change in the flux (first one way and then the other) would induce an EMF and the resulting eddy currents would impede the progress of the blades.
Come to think of it, the answer is almost certainly zero. Can you think of why? What are helicopter blades typically made of?
If you want to get the right answer with your blv method you have to divide the speed by 2 because you need the average speed of the blade, not just the tip.
Let's see... What's one half of zero...
FAQ: Electromagnetic Induction Question
What is electromagnetic induction?
Electromagnetic induction is the process by which a changing magnetic field produces an electric current in a conductor. This phenomenon is the basis for many important technologies, such as generators, transformers, and electric motors.
Who discovered electromagnetic induction?
Electromagnetic induction was first discovered by Michael Faraday in 1831. He observed that when a magnet is moved back and forth inside a coil of wire, it produces an electric current in the wire.
What is Faraday's law of induction?
Faraday's law of induction states that the voltage induced in a circuit is directly proportional to the rate of change of the magnetic flux through the circuit. In simpler terms, it means that the more quickly a magnetic field changes, the larger the induced voltage will be.
What is Lenz's law?
Lenz's law is a consequence of Faraday's law and states that the direction of the induced current in a conductor will always be such that it opposes the change in magnetic flux that caused it. This law helps to explain why electromagnetic induction results in a current flowing in a specific direction.
What are some practical applications of electromagnetic induction?
Electromagnetic induction has many practical applications, including power generation, induction heating, wireless charging, and data transmission. It is also used in devices such as electric motors, transformers, and generators.
