crx
- 81
I was thinking at electromagnetic induction in two parallel wires...I searched some websites about this and i found out that acording to Lenz's law :"An induced current is always in such a direction as to oppose the motion or change causing it". Acording to this an induced current is opposig the original (inductor) current (180 phase shift).. So i did a similar experiment. I sent square pulses and a sin wave in a wire parallel to another wire and hooked them up to an oscope. I saw that actually the induced signal is in phase with the original signal. So what i learned is that an induced current is is the same dirrection with the original current... Even when i approached a magnet to a coil the induced current had the same direction with the imaginarry current that would make up the magnetic field (in respect with the N-S poles) of the magnet. This doesn't seem to listen to the Lenz's law, so i guess i did something wrong...
Could some of you do some quick experiments to see exactly what the results are?
thanks
thanks
