Why Does EMF Change as a Magnet Passes Through a Coil?
In summary, when a magnet is dropped through a coil, the changing magnetic field induces a current in the coil, resulting in a voltage that increases, decreases, and then increases again as the magnet falls through the coil. The magnet can remain in the coil for several seconds and still induce a voltage due to Faraday's law of induction.
jsmith613
614
If I take a magnet and drop it though coil then the graph would have an increasing voltage until a maximum and then a reducing emf (until 0) and then a further reducing emf until a minimum and then an increasing emf again
graph looks like this: http://www.djb.co.uk/Graphics/Physics/Teachers/magnet.gif
Remember the magnet remains wholy in the coil for several seconds.
Questions:
1) why does the EMF gradually increase then decrease until 0 then decrease further and then increase again??
2) if the magnet remained wholly in the coil for a while will any voltage be induced? why?
no questions
1) well if the magnet falls straight through the polarity changes but this also confuses me. how can it change if the magnet is falling through without chaging direction?
2) Yes, voltage will still be induced because the changing magnetic field created by the falling magnet will still induce a current in the coil, regardless of the duration of time the magnet remains in the coil. The induced voltage will decrease as the magnet falls further away from the coil, resulting in the decrease and then increase in EMF shown in the graph. This phenomenon is known as Faraday's law of induction. The changing magnetic field induces a current in the coil, which in turn creates a magnetic field that opposes the original change in the magnetic field, leading to the decrease in EMF. As the magnet moves further away from the coil, the induced current and magnetic field weaken, resulting in the increase in EMF again. This process repeats until the magnet reaches the bottom of the coil.
FAQ: Why Does EMF Change as a Magnet Passes Through a Coil?
What is electromagnetic induction?
Electromagnetic induction is the process of creating an electric current in a conductor by changing the magnetic field around it.
How does electromagnetic induction work?
Electromagnetic induction works by using a changing magnetic field to induce an electric current in a conductor. This can be achieved by moving a magnet near a conductor or by changing the current in a nearby coil of wire.
What is the significance of electromagnetic induction?
Electromagnetic induction is significant because it allows for the generation of electricity, which is used in many everyday devices such as generators, motors, and transformers. It also plays a crucial role in the functioning of electronic devices and the transmission of power over long distances.
What are some real-world applications of electromagnetic induction?
Some common real-world applications of electromagnetic induction include power generation in hydroelectric dams and wind turbines, electric motors, wireless charging, induction cooktops, and magnetic levitation trains.
How does electromagnetic induction relate to Faraday's law?
Faraday's law of induction states that the magnitude of the induced electromotive force (EMF) in a closed circuit is proportional to the rate of change of the magnetic flux through the circuit. This is the fundamental principle behind electromagnetic induction.
