Vectronix
- 65
- 2
Why isn't EM radiation attracted/repelled by a magnetic field?
Why would it be? EM radiation is electromagnetic waves and the EM field has no self-interactions.Vectronix said:Why isn't EM radiation attracted/repelled by a magnetic field?
The magnetic vector component of a passing EM wave, is linearly added to the magnetic field, without either being changed. As the wave departs the magnetic field, the EM wave is restored to its original form.Vectronix said:Why isn't EM radiation attracted/repelled by a magnetic field?
but in a non linear medium, two different EM fields are often found to interact. For example, in the Ionosphere signals from a powerful radio station can cross modulate with a weaker transmission and you hear both programmes when tuned to the weaker one. This ionospheric non-linearity is due to the motion of free electrons in the presence of the Earth's magnetic field - and in many ways it 'almost' a vacuum up there!tech99 said:In a vacuum the two do not interact
That's a risk of course. But the non interaction of EM fields is only an ideal concept and relies on linearity. The question is similar to the discussions of c. c is only c under the same conditions as EM waves not interacting.Vanadium 50 said:Are we trying to confuse him?
The OP wrongly asserts that there is never a directional interaction.Vanadium 50 said:We have a B level thread with some good answers and what do we do "Hey, lets toss in some non-linear media that the OP did not even ask about!"
c is always c and should be reserved for the invariant speed in relativity. Whether light travels at that speed is a different question that is medium dependent.sophiecentaur said:That's a risk of course. But the non interaction of EM fields is only an ideal concept and relies on linearity. The question is similar to the discussions of c. c is only c under the same conditions as EM waves not interacting.
There isn’t. Not between the gauge field and itself. There may be secondary interactions that are introduced by the precence of a medium, but the U(1) gauge field itself is not self-interacting due to the gauge group being Abelian.Baluncore said:The OP wrongly asserts that there is never a directional interaction.
What about it?Vectronix said:What about vector addition?
It is linear.Vanadium 50 said:What about it?
If you measure the fields at a chosen place, you will get the vector sum. Away from that spot you will get a different value. The two fields interact with your equipment (bad choice of phrase perhaps) but not with each other.Vectronix said:What about vector addition?
That's not interaction. Interaction would be happening if the level of one wave were actually affected by the presence of the other. When you measure the field in a particular place, your measurement will have contributions from each and so you would have just one meter / receiver reading. That reading, by combining information about both waves into, say, a loudspoeaker, may show 'beats' but when the two waves have separated out again, on their different paths, they are unaffected by each other. Two separate receivers in two places would confirm that.alan123hk said:but could this be called interaction
No. You can always write the total field as the sum of the undisturbed magnetic field and the undisturbed wave.Vectronix said:(Re: vector addition) Does the magnetic field in the EM radiation combine at all with an external electromagnetic field or does it change its polarization?
What kind of external electromagnetic field is this? Is it an electrostatic field, a static magnetic field, or other radiated electromagnetic fields? How are they combined? Is it a simple superposition or a combination through special devices?Vectronix said:(Re: vector addition) Does the magnetic field in the EM radiation combine at all with an external electromagnetic field or does it change its polarization?
They do add up to create a superposition. It is just that this does not affect the wave itself.Vectronix said:I was imagining the little arrows on the EM wave adding up with the static magnetic field like vector addition, changing the direction of the magnetic component of the wave
