Electromagnetic Radiation Theory & Math Questions help please
In summary, as the light intensity increases, the photocurrent and speed of the photoelectrons also increase. As the frequency of the light increases, only the speed of the photoelectrons increases. When a radiation with a frequency of 6.67 * 10^14 Hz is used to illuminate a photoelectric surface with a threshold frequency of 2.50eV, the ejected electrons are deflected by a perpendicular magnetic field. Using the formula E=hf, the kinetic energy of the electrons is calculated to be 4.2221 *10^-20. The force on the electrons in the magnetic field is calculated using F=evB, and the radius of the deflected electrons is determined using the formula for centrip
skg94
79
1. Explain the effects
To the photocurrent as the light intensity increases
To the photocurrent as the frequency of the light is increased
To the speed of the photoelectrons as the radiation intensity increases
To the speed of the photelectrons as the radiation frequency increases
2. Radiation with a frequency of 6.67 * 10^14 Hz is used to illuminate a photoelectric surface (W=2.50eV). The ejected electrons are now deflected by a perpendicular magnetic field (B=3.11*10^-5T). What is the maximum radius of these deflected electrons? [ANS: 5.57 * 10^-2m ]
Ek = hf-W
W=hfo
c=f (lambda - wavelength)
1.a) more current
b) nothing
c) increases speed
d) increases speed - i don't really know how do i solve this? some help here
2. I really have no idea
i got E, from E=hf-W = 4.2221 *10^-20, but i don't know how to fuse B with E to find radius, maybe Fm=Fc? but so many unknowns.
In response, to question 1,
1. As your intensity of light increases, the NUMBER of photons hitting the surface of your material will increase. Thus, the number of electrons emitted will increase, and, as you have said, increase the current.
2. Keeping mind the presence of the threshold frequency, which is the minimum energy each photons have to give to a metal to enable the emission of an electron, understand intuitively that increasing the energy of a photon will not affect the number of electrons released. There will be a spike from 0 at the threshold frequency, but otherwise, the current is unaffected.
3. As the number of photons hitting a metal surface increases (i.e. as Intensity increases) the kinetic energy given to each electron is unaffected, even though more electrons are emitted. Thus, speed is unaffected.
4. As radiation frequency increases, obviously, more energy is given to an electron, which, after allowing it to break free from the surface of the metal, gives it Kinetic Energy, which shows in the form of greater speed.
What is probably confusing you is the relationship between Energy and Frequency. Remember the formula E=Hf, where E is energy, h is the Planck Constant and f is the frequency of the wave.
Ah true applying it to the forumla is easiest, so as intensity increases. current increases but speed remains the same, as frequency increases current reamains the same while speed increases - is that correct?
Anyone know how to do question 2?
The value you've calculated for E is the kinetic energy of the photoelectron.
Work out the speed of the electron from this.
The force on the electron in the magnetic field is
F = evB.
This force holds the electron in a circular path, so it's the centripetal force.
If you use the formula for the centripetal force, you should be able to calculate the radius.
Related to Electromagnetic Radiation Theory & Math Questions help please
1. What is electromagnetic radiation?
Electromagnetic radiation refers to the energy that is emitted in the form of waves or particles from the movement of electrically charged particles. It includes a wide range of wavelengths, from radio waves to gamma rays.
2. How does electromagnetic radiation interact with matter?
When electromagnetic radiation encounters matter, it can be absorbed, reflected, or transmitted. The interaction depends on the properties of the matter, such as its composition and structure, and the wavelength of the radiation.
3. What is the electromagnetic spectrum?
The electromagnetic spectrum is the range of all types of electromagnetic radiation. It includes radio waves, microwaves, infrared radiation, visible light, ultraviolet radiation, X-rays, and gamma rays. Each type has a different wavelength and energy, and they are all forms of electromagnetic radiation.
4. How is electromagnetic radiation measured?
Electromagnetic radiation is measured in units of frequency and wavelength. Frequency is measured in Hertz (Hz), which represents the number of cycles per second, and wavelength is measured in meters (m). The relationship between frequency and wavelength is inversely proportional, meaning that as the frequency increases, the wavelength decreases.
5. How is electromagnetic radiation used in everyday life?
Electromagnetic radiation is used in various ways in our daily lives. For example, radio waves are used for communication, microwaves are used for cooking, infrared radiation is used for heat and thermal imaging, visible light is used for vision, and X-rays are used for medical imaging. The different types of electromagnetic radiation have different properties and applications, making them essential in many aspects of our modern society.
  • Electromagnetism
