Electromagnetic Wave Calculations
In summary: Yes, that's correct. But, the "given frequency" is NOT the frequency in the medium. You are asked for the vacuum wavelength. So where is the phase constant? And how does a phase constant factor into the calculations for λ 0 \lambda_0? A sinusoidal wave has the form f(z,t)=Acos(kz−ωt+δ) f(z,t)=A \cos (kz-\omega t + \delta), where δ \delta is the phase constant. So in the given equation for E, I don't see a phase constant... Yes, the phase constant is zero. So, it does not factor into the calculation. That's the point. You
roam
1,271
A monochromatic, electromagnetic plane wave is traveling in a non-conducting, transparent medium. Its real electric field is described by:
##E=100 \ cos (7.62 \times 10^6 (x+y+z) \ - \ 2.98 \times 10^{15} t) \ \frac{1}{\sqrt{5}} (\hat{y} + 2 \hat{z}) \ V/m##
(a) What would be the vacuum wavelength of the wave?
(b) What is the refractive index of the medium?
(c) In what direction is the wave travelling?
##\lambda = 2\pi/k, \ \ v=\omega/k, \ \ n=ck/\omega##
Real electric field general expression:
##E(r,t)=E_0 \ cos(k.r-\omega t) \hat{n}##
Where ##\hat{n}## represents the polarization.
(a) I have tried to do this part using the two different equations: ##\lambda = 2\pi/k## and ##\lambda=c/\nu##. But each time I get a different answer:
##\lambda = \frac{2 \pi}{k} = \frac{2 \pi}{7.62 \times 10^6}= 824.5 \ nm##​
And since ##\nu = \omega / 2\pi## we have:
##\lambda = \frac{c}{\nu} = \frac{3 \times 10^8}{(2.98\times 10^{15})/2\pi} = 632.5 \ nm##​
So which method is correct? :confused:
(b) For refractive index I got:
##n= \frac{ck}{\omega} = \frac{(3 \times 10^8)(7.62 \times 10^6)}{2.98 \times 10^{15}} = 0.76##​
But this doesn't look right. Shouldn't n be greater than or equal to 1?
(c) Since the expression for electric field has the general form ##cos(kz-\omega t)##, I believe it is traveling to the right. But how do I explain the "x+y+z" part? What plane or line is the direction of travel parallel/perpendicular to?
Any explanation would be greatly appreciated.
As a potential bump in the right direction, keep in mind that the EM wave in this problem isn't necessarily traveling in vacuum, i.e., the speed of the wave isn't necessarily ##c##.
Likes EM_Guy
(a) Note that the problem asks, "What would be the vacuum wavelength of the wave?" The wave is not propagating in a vacuum. So, the answer to this question is not the wavelength of the wave in the medium. So, the problem gives you a phase constant (sort of - you have to figure it out since the wave is propagating in an oblique direction). The problem also gives you the frequency of the wave. You know what the speed of light in a vacuum is. (And you should remember that the speed of light in a dielectric is not equal to the speed of light in a vacuum). You also know the frequency of the wave. So, what would be the vacuum wavelength of the wave?
(b) You need to figure out the phase constant of the wave (be careful - the wave is traveling in an oblique direction). Then think about how the phase constant, the frequency, and the index of refraction are related to each other. If you don't know, think about the velocity of the wave (remembering that the velocity in the medium is less than the speed of light).
(c) Clearly, the (x+y+z) indicates that the wave is traveling in an oblique direction. You need to figure out the unit vector specifying the direction of travel. Keep in mind that cos(-A) = cos(A). Set up a phasor representation of the E-field.
So, my second method was correct? (i.e. ##\lambda_0 = c/\nu = 632.5 \ nm##)
Vacuum wavelength is given by ##\lambda_0 = \lambda n##. As n is increased, ##\lambda## decreases because frequency is unchanged when speed decreases. Since the given frequency is same as vacuum frequency AND I know the vacuum speed, I just used the relationship ##\lambda = c/\nu##.
So where is the phase constant? And how does a phase constant factor into the calculations for ##\lambda_0##?
A sinusoidal wave has the form ##f(z,t)=A \ cos (kz-\omega t + \delta)##, where ##\delta## is the phase constant. So in the given equation for ##E##, I don't see a phase constant...
I know we can use ##n=v_{medium}/c## (If we know the wave velocity in the medium). But why is it not possible to use ##n=ck/\omega## as I did?
That was my question. How do we find the unit vector representing that direction? :confused:
My textbook (Griffiths) does not explain this, and I've posted similar problems in other threads before but unfortunately I couldn't get any help with those. Any explanation or links on how to do this part would really be appreciated.
roam said:
So, my second method was correct? (i.e. λ 0 =c/ν=632.5 nm \lambda_0 = c/\nu = 632.5 \ nm)
Yes.
roam said:
Vacuum wavelength is given by λ 0 =λn \lambda_0 = \lambda n. As n is increased, λ \lambda decreases because frequency is unchanged when speed decreases. Since the given frequency is same as vacuum frequency AND I know the vacuum speed, I just used the relationship λ=c/ν \lambda = c/\nu.
I don't know what n is.
roam said:
A sinusoidal wave has the form f(z,t)=A cos(kzωt+δ) f(z,t)=A \ cos (kz-\omega t + \delta), where δ \delta is the phase constant. So in the given equation for E E, I don't see a phase constant...
No. k is your phase constant (rad/m). You need to figure out how the phase constant, the speed of the wave, and the frequency of the wave relate to each other.
Consider this function: f(z,t) = cos(wt - kz). This has a value of 1 as long as wt-kz = 0. Now, as t increases (as it always does), z must also increase in order for f(z,t) = 1. That is, this wave is propagating in the positive z direction. But how fast? Well, v = dz/dt. So, if we make wt - kz = 0, then we are saying wt = kz, or wt/k = z.
v = dz/dt = w/k.
Excuse my notation. I don't know how to do equations on PF. If you could let me know how you do this, I would appreciate it.
Let me know how to write equations on PF, and I'll be happy to explain this to you. It is not easy. I don't think that most students would be able to get it just by thinking really hard. But once it is explained, it is readily understandable - to most students. It is just hard to explain with words.
To write your equations in LaTeX, simply include your code within double hash tags (##), or between [tex] [/tex].
Here are the common LaTex commands.
##n## is the refractive index, of course.
I used the equation relating k to ##\omega## to find it:
##n = \frac{c k}{\omega} = 0.7##​
But "0.7" cannot be a valid refractive index. What's wrong? :confused:
It seems like you have a couple of problems here.
It appears that your value for k is 6.9533 x 10^6. Is that what you have? How did you get that?
I couldn't figure out how to do this in latex (with all the superscripts and hats, etc.). But check out the attached. You need to recognize that the ##7.62(10^6) (x + y + z)## term in the argument is a dot product of your beta vector and your position vector. Given a position vector, you should be able to find a unit vector in the same direction (just divide the position vector by the magnitude of the position vector). Find your beta.
Oh, and what I'm calling beta is often called k.
  • Electric Field Representation.docx
Likes roam
Can you possibly mention the link or book from which you found this problem, because the propagation direction and polarization vector in
are not perpendicular, as it should if the wave is propagating in an isotropic medium.
blue_leaf77 said:
Can you possibly mention the link or book from which you found this problem, because the propagation direction and polarization vector are not perpendicular, as it should if the wave is propagating in an isotropic medium.
I think we are talking about a guided wave here.
In any isotropic medium, be it guiding or not, we have the relation
$$ \epsilon_R \frac{\omega^2}{c^2} (\mathbf{k} \cdot \mathbf{\hat{u}})= 0$$
where ##\mathbf{\hat{u}}## is the unit vector along the polarization, we see that in order to satisfy that equation the wavevector must be perpendicular to the polarization.
blue_leaf,
Are you saying that in any isotropic medium - even in waveguides - all electromagnetic waves are TEM?
Maybe I should have been careful in saying that general statement, that equation can be derived simply by using Maxwell equations by requiring that the solution is a plane wave, that i,s the surface of constant phase is a flat surface, constant amplitude, and uniform wavevector, and in addition the permittivity is scalar not a tensor as it is in anisotropic media . These requirements will in turn give that equation.
The difference between guiding and infinitely large extend medium is the presence of boundary conditions, and due to this the amplitude of the propagating E field should be a function of space, which is not the case in the original problem posted by the OP.
I think the polarization of this wave can be ignored in this problem. It is not necessary to answer the questions asked.
For part (a) probably it is not needed. But the OP's answer to part (b) looks fishy, therefore we need to know the exact problem and in which context he/she got it, only the OP can tell us.
The OP's answer to part (b) is wrong. I worked the problem - ignoring polarization - and got the answer to part (b).
Likes blue_leaf77
Ah I failed to notice that he used the wrong value for ##k##.
So, the unit vector is ##\frac{\hat{x}+\hat{y}+\hat{z}}{\sqrt{3}}##?
So I need to multiply ##k=7.62 \times 10^6## with √3 to get the right k?
This is what I got:
##n=\frac{c(k=7.62 \times 10^6)}{\omega=2.98 \times 10^{15}} (\sqrt{3}) = 1.2##
Is this right? The answer looks more realistic (it's close to the refractive index of water, for instance)
This is a question from an old exam paper.
This is what I got:
Your unit vector is correct. But you are not multiplying k by ##\sqrt{3}##. Rather you are multiplying ##7.62 \times 10^6## by ## \sqrt{3} ## to get k. That's your k. ##7.62 \times 10^6## is not your k.
Somehow your answer is off though. I get ##n = 1.329##. Check your arithmetic.
Likes roam
Alright, thank you so much for the help!
Related to Electromagnetic Wave Calculations
1. What is an electromagnetic wave?
An electromagnetic wave is a type of energy that is created by the movement of electrically charged particles. It consists of an electric field and a magnetic field, which are perpendicular to each other and travel through space at the speed of light.
2. How are electromagnetic waves calculated?
Electromagnetic waves can be calculated using the equation c = λv, where c is the speed of light, λ is the wavelength, and v is the frequency. Additionally, the energy of an electromagnetic wave can be calculated using the equation E = hf, where h is Planck's constant and f is the frequency.
3. What are some common applications of electromagnetic wave calculations?
Electromagnetic wave calculations are used in a variety of fields, including telecommunications, astronomy, and medical imaging. They are also used in everyday devices such as radios, televisions, and cell phones.
4. How are electromagnetic waves related to the electromagnetic spectrum?
The electromagnetic spectrum is a range of all possible wavelengths of electromagnetic radiation. Electromagnetic waves are categorized within this spectrum based on their wavelength and frequency. Longer wavelengths correspond to lower frequencies, while shorter wavelengths correspond to higher frequencies.
5. What factors can affect the propagation of electromagnetic waves?
The propagation of electromagnetic waves can be affected by several factors, including the medium through which the wave travels, the presence of obstacles or interference, and the frequency of the wave. These factors can cause the wave to bend, reflect, or be absorbed, altering its path and intensity.
