Electromagnetic waves in charged/magnetic fields
In summary, the conversation discusses the lack of interaction between electromagnetic waves and charged/magnetic fields. The presence of a magnet or charged particle does not affect the propagation of electromagnetic waves, unlike other materials where electrons can alter their polarization. This is due to the fact that photons, the particles that make up electromagnetic waves, do not have charge or mass. The concept of virtual photons is purely conceptual and does not have a physical existence. It is important to note that this is a classical question and does not require the use of quantum electrodynamics or photons.
Sophrosyne
128
Electromagnetic waves are oscillations of the electrical/magnetic field which propogate through space. So one might predict that the presence of a magnet/charged particle would effect their propogation somehow, like distortion or interference (eg, light might get refracted in a magnetic field or in the presence of a charged object). But it doesn't. Why not?
Sophrosyne said:
Summary: Why aren't electromagnetic waves effected by the presence of charged/magnetic fields?
have a think about an EM field/wave and what it needs ( but doesn't have) to be affected by a magnetic field ?
or conversely … what does an electron have, that an EM field/wave doesn't, that allows it to be deflected by a magnetic field ?
Dave
Likes artis
Dave
I would think a charge?
Likes davenn
yes charge, influencing the trajectory and kinetic energy of a charge with the help of a magnetic field does create EM radiation, such is done in cyclotrons for example and elsewhere.
If you could affect EM radiation itself with a magnet then you could also alter your vision by bringing a strong magnet close to your eyes, but nothing happens to the light that you see, because EM radiation is made up from particles called photons that among other things have no charge and no mass.
Likes davenn
I am trying to find a way to articulate where my confusion is coming from. I guess it comes from the fact that electromagnetic waves (ie, photons) from two charged/magnetic objects can interact with each other: interference, coherence, cancelling each other out, etc (eg, a positive and negative charge cancel each other out)... Similarly, light waves/photons interact with each other in a similar way (eg, double slit experiment). But they don't interact with each other. So why can't the photons from a magnet or charged particle interact similarly with light waves or other electromagnetic waves?
Does it have something to do with the difference between virtual and real photons? (ie, virtual photons and real photons only interact within their own class, not with each other). Is this the right way to think about it?
Or does it have to do with the impossibility of getting such classes of photons to interact in/out of phase? It seems it wouldn't be THAT difficult to create photons of equal energy from each class and so get them to interact in/out of phase.
That doesn't make sense
magnets don't produce photons
So how do magnets interact with charged particles or other magnets? I thought in field theory/electrodynamics they were called “virtual photons”. Are these just a purely conceptual/mathematical concept and have nothing to do with real photons?
yes, but you do understand that they don't actually exist ? that is ... they are not physical ?
A charge particle will effect the propagation of an EM wave.
For instance, when light hits a shiny conductor. And when light enters a prism.
When light travels through a medium other than vacuum, there are electrons, which will move in response to the wave and influence its propagation.
On the other hand, an electric or magnetic field in a vacuum will not influence the wave. But such fields in some materials will alter the polarisation, for instance, the Faraday rotation in glass, but then we have particles involved once again.
Whenever an EM wave is altered somehow, by absorption, reflection, refraction, diffraction etc, there is a charged particle doing it, usually electrons.
  • Skeptical
Likes davenn
It's a good rule of thumb not to invoke quantum electrodynamics and photons unless it's really necessary. Photons are highly non-intuitive entities and they are not like little bullets flying around. Your question is purely classical, so there is no need to talk about photons.
Likes vanhees71, davenn and artis
I see. I think I understand. Thank you very much.
Likes weirdoguy
FAQ: Electromagnetic waves in charged/magnetic fields
1. What are electromagnetic waves?
Electromagnetic waves are a type of energy that is created when an electric field and a magnetic field oscillate or vibrate at right angles to each other. They are also known as electromagnetic radiation and can travel through space or a medium, such as air or water.
2. How are electromagnetic waves produced in charged/magnetic fields?
Electromagnetic waves are produced when charged particles, such as electrons, are accelerated or moved back and forth in a magnetic field. This movement creates a changing electric field, which in turn creates a changing magnetic field. These two fields then interact with each other to create electromagnetic waves.
3. What is the relationship between the strength of the electric/magnetic field and the intensity of the electromagnetic waves?
The strength of the electric and magnetic fields determines the intensity of the electromagnetic waves. The stronger the fields, the more energy the waves will carry. This means that the intensity of the waves can be increased by increasing the strength of the electric or magnetic field.
4. How do electromagnetic waves behave in different media?
Electromagnetic waves can travel through a vacuum, such as space, at the speed of light. However, their speed and behavior can be affected by different media, such as air, water, or glass. In these mediums, the waves may be absorbed, reflected, or refracted, depending on their frequency and the properties of the medium.
5. What are some practical applications of electromagnetic waves in charged/magnetic fields?
Electromagnetic waves have a wide range of practical applications, including communication technologies such as radio, television, and cell phones. They are also used in medical imaging, such as X-rays and MRI scans, and in industrial processes, such as welding and heating. Additionally, electromagnetic waves are used in scientific research, such as in telescopes and particle accelerators.
