Electromagnetism - Dielectric and Various Cavities
In summary, the conversation discusses the properties of electric fields inside cavities in a large block of dielectric material. It is shown that inside a needle-like cavity parallel to the uniform polarization, the electric field is the same as in the dielectric. Inside a thin crack perpendicular to the polarization, the electric field is εr times larger than in the dielectric. At the center of a small spherical cavity, the electric field is P/3*μ0. The use of continuity rules for E and D fields is suggested to solve the problems, and the importance of considering the absence of free charge at the air-dielectric interface is emphasized.
MITlurker
A large block of dielectric contains small cavities of various shapes whose sizes are much smaller than the block. The dielectric has uniform polarization P except those cavities which are assumed not to disturb the polarization of dielectric.
(a) Show that, inside a needle-like cavity parallel to P, the electric field E(inside the cavity) is the same as in the dielectric.
(b) Show that, inside a thin crack perpendicular to P, the electric field E(inside the cavity) is εr times larger than in the dielectric.
(c) Show that, at the center of a small spherical cavity, E=P/3*μ0.
Attempt at Solution:
a) q = σbA = P*A
Working this out E = [itex]\frac{PA}{∏εl^2}[/itex] - [itex]\frac{-PA}{∏εl^2}[/itex]
l is the length of the slit
E = [itex]\frac{2PA}{∏εl^2}[/itex] Z
However as A is very small in that direction, E needle is close to zero. So E0 is the E-field in the cavity.
b) This is where I'm stuck.
I assumed that the slit acted like a plate capacitor and attempted to go from there with σ+ on the top and σ- on the bottom. However, I get the E field of the perpendicular cavity is E0 + P/ε, which is not a multiple of εr
E = - ∇V
E = [itex]\frac{V}{d}[/itex], where d should be considered extremely small in part (b)
For a) and b) I would use continuity rules of E and D fields parallel and perpendicular to an air-dielectric interface. What are they? You might want to be in a position to defend them if called upon ...
Hints:
a) what would discontinuity of the E field imply that we know is incorrect?
b) what would discontinuity of D imply that we know is incorrect? Realize there is no free charge at the air-dielectric interface. (D = epsilon*E for both air and dielectric).
c) got to think about that one.
Related to Electromagnetism - Dielectric and Various Cavities
1. What is the difference between a dielectric and a conductor?
A dielectric is a material that does not conduct electricity, while a conductor is a material that allows electricity to flow through it easily. Dielectrics can become polarized when placed in an electric field, while conductors do not.
2. How do dielectrics affect the electric field in a cavity?
Dielectrics can change the electric field in a cavity by becoming polarized, which can either increase or decrease the strength of the electric field depending on the dielectric constant of the material.
3. What is the purpose of using a dielectric in a cavity?
A dielectric is often used in a cavity to increase the capacitance and reduce the resonant frequency. It can also improve the efficiency and performance of the cavity by reducing losses and increasing the quality factor.
4. How does the shape of a cavity affect its electromagnetic properties?
The shape of a cavity can significantly impact its electromagnetic properties. For example, a cylindrical cavity has different resonant frequencies and electric field patterns compared to a rectangular cavity.
5. Can different types of cavities be used for specific applications?
Yes, different types of cavities can be used for various applications. For instance, a rectangular cavity is commonly used in microwave ovens, while a cylindrical cavity is often used in particle accelerators. The shape and size of the cavity can also affect its resonant frequency and electric field distribution, making it suitable for specific purposes.
  • Atomic and Condensed Matter
  • Electromagnetism
  • Electromagnetism
