Electromagnetism equivalence theorem
In summary, the Love's Theorem in Electromagnetism states that it is possible to find another solution to Maxwell's equations, in which the volume V enclosed by S is filled with a Perfect Electric Conductor.
EmilyRuck
136
Hello!
In http://my.ece.ucsb.edu/York/Bobsclass/201C/Handouts/Chap1.pdf, pages 19-20, the Love's Theorem in Electromagnetism is declared. In presence of some electric sources [itex]\mathbf{J}[/itex] and magnetic sources [itex]\mathbf{M}[/itex] enclosed by an arbitrary geometrical surface [itex]S[/itex], which produce outside [itex]S[/itex] a field [itex]\mathbf{E}, \mathbf{H}[/itex] and on [itex]S[/itex] a field [itex]\mathbf{E}_S, \mathbf{H}_S[/itex], it is possible to find another solution to Maxwell's equations with:
  • zero sources and zero fields inside [itex]S[/itex];
  • the same field [itex]\mathbf{E}, \mathbf{H}[/itex] outside [itex]S[/itex];
  • impressed [itex]\mathbf{J}_S = \mathbf{\hat{n}} \times \mathbf{H}_S[/itex] and [itex]\mathbf{M}_S = \mathbf{E}_S \times \mathbf{\hat{n}}[/itex] surface currents on [itex]S[/itex].
But there is an alternative solution, in which the volume [itex]V[/itex] enclosed by [itex]S[/itex] is filled with a Perfect Electric Conductor (PEC). In this case we should have:
  • again zero sources and zero fields inside [itex]S[/itex] due to the PEC;
  • a field [itex]\mathbf{E}, \mathbf{H}[/itex] outside [itex]S[/itex];
  • only impressed [itex]\mathbf{M}_S = \mathbf{E}_S \times \mathbf{\hat{n}}[/itex] surface currents on [itex]S[/itex].
According to the Uniqueness Theorem, a solution to Maxwell's equation is unique if the sources and the boudary conditions (relative to [itex]\mathbf{E}[/itex] OR to [itex]\mathbf{H}[/itex]) are provided and this fact is exploited in order to prove the Equivalence Theorem just written in its two forms.
My questions are:
  1. If the boundary conditions of [itex]\mathbf{E}[/itex] OR to [itex]\mathbf{H}[/itex] are required, why in the first case we need to specify both the surface currents?
  2. How can the only [itex]\mathbf{M}_S[/itex] currents generate both the fields in the second case?
Thank you for having read.
Emily
I'm not sure, how to prove these equivalence theorems. Perhaps you can achieve it, using the retarded potentials.
EmilyRuck said:
Hello!
My questions are:
Emily
Here are my best answers for the moment ...
1. Because you were specifying the field both inside and outside of [itex]S[/itex], so in some sense you need conditions for both the internal and external problems. If you don't care about the fields inside of S you should be able to construct a solution using either a magnetic or an electric surface current that gnerates the correct fields outside of S, but nonzero fields inside of S. For example, what if you assume there is no discontinuity of the electric field across the S?
2. In the second case the magnetic current is radiating in the presence of the PEC; this is completely different than radiating in a homogeneous space.
jason
Related to Electromagnetism equivalence theorem
1. What is the Electromagnetism Equivalence Theorem?
The Electromagnetism Equivalence Theorem states that the electric field and magnetic field are two aspects of the same phenomenon, known as the electromagnetic field. This means that an electric field can be created by a changing magnetic field, and a magnetic field can be created by a changing electric field.
2. Who discovered the Electromagnetism Equivalence Theorem?
The Electromagnetism Equivalence Theorem was first proposed by Scottish scientist James Clerk Maxwell in the 19th century. Maxwell's equations, which describe the behavior of electromagnetic fields, formed the basis for this theorem.
3. How is the Electromagnetism Equivalence Theorem applied in real life?
The Electromagnetism Equivalence Theorem has many practical applications. For example, it is used in the development of technologies such as electric motors, generators, and transformers. It is also the basis for understanding how electromagnetic waves, such as radio waves and light, propagate through space.
4. What is the significance of the Electromagnetism Equivalence Theorem?
The Electromagnetism Equivalence Theorem is significant because it unified the theories of electricity and magnetism, which were previously thought of as separate phenomena. This allowed for a better understanding of electromagnetic interactions and paved the way for the development of new technologies.
5. Are there any exceptions to the Electromagnetism Equivalence Theorem?
While the Electromagnetism Equivalence Theorem holds true in most cases, there are some exceptions. For example, in very strong magnetic fields or at very high energies, the equivalence between electric and magnetic fields breaks down. Additionally, in certain quantum mechanical systems, the theorem does not apply.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
