[Electromagnetism] Force on a moving charge expression
In summary, the force on a moving charge is given by- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
carlosbgois
68
[/B]
The total force on a moving charge q with velocity v is given by [tex]\mathbf{F}=q(\mathbf{E}+\mathbf{v}\times\mathbf{B})[/tex] Using the scalar and vector potentials, show that [tex]\mathbf{F}=q[-\nabla\phi-\frac{d\mathbf{A}}{dt}+\nabla(\mathbf{A}\cdot\mathbf{v})][/tex]
[/B]
(1) [tex]\mathbf{E}=-\frac{d\mathbf{A}}{dt}-\nabla\phi[/tex]
(2) [tex]\mathbf{B}=\nabla\times\mathbf{A}[/tex]
(3) [tex]\mathbf{v}\times(\nabla\times\mathbf{A})=\nabla(\mathbf{v}\cdot\mathbf{A})-\mathbf{A}(\mathbf{v}\cdot\nabla)[/tex]
[tex]\mathbf{F}=q(\mathbf{E}+\mathbf{v}\times\mathbf{B})=q[-\nabla\phi-\frac{d\mathbf{A}}{dt}+\mathbf{v}\times\mathbf{B}][/tex]
Now I need to show that
[tex]\mathbf{v}\times\mathbf{B}=\nabla(\mathbf{A}\cdot\mathbf{v})[/tex]
I tried applying (3) but didn't know where to go from there.
carlosbgois said:
[/B]
Here, the time derivative should be a partial derivative ##\frac{\partial \mathbf{A}}{\partial t}## ; i.e., it denotes the rate of change of ##\mathbf{A}## at a fixed point of space. But in the final expression that you want to get to for the force, the derivative is the "convective" time derivative ##\frac{d\mathbf{A}}{dt}## ; i.e., it denotes the rate of change of ##\mathbf{A}## as you move along with the particle. You will need to relate the two types of derivatives. See http://www.continuummechanics.org/cm/materialderivative.html
The last term is not quite written correctly. In your way of writing it, the Del operator has nothing to act upon.
As TSny said [itex]\mathbf{E}=-\nabla \phi - \partial_t \mathbf{A}[/itex] nowusing the triple product identity:
[tex]\mathbf{v}\times(\nabla \times \mathbf{A}) = \nabla(\mathbf{A} \cdot \mathbf{v}) - \mathbf{A}(\mathbf{v} \cdot \nabla)[/tex]
Which in the Lorentz equation:
[tex]\mathbf{F} = q \left[-\nabla \phi - \partial_t \mathbf{A} + \nabla(\mathbf{A} \cdot \mathbf{v}) - \mathbf{A}(\mathbf{v} \cdot \nabla) \right] [/tex]
or
[tex]\mathbf{F} = q \left[-\nabla \phi - [\partial_t + (\mathbf{v} \cdot \nabla) ] \mathbf{A} + \nabla(\mathbf{A} \cdot \mathbf{v})\right] [/tex]
where the term in the square bracket acting on [itex]\mathbf{A}[/itex] is called the convective derivative, viz. [itex](\partial_t + (\mathbf{v} \cdot \nabla) ) \mathbf{A} = \frac{d \mathbf{A}}{dt}[/itex] as required.
Got it! Thank you all.
Related to [Electromagnetism] Force on a moving charge expression
1. What is the force on a moving charge expression in electromagnetism?
The force on a moving charge expression in electromagnetism is given by the formula F = q(E + v x B), where q is the charge, E is the electric field, v is the velocity of the charge, and B is the magnetic field.
2. How is the force on a moving charge expression derived?
The force on a moving charge expression is derived from the Lorentz force law, which states that a charged particle in an electric and magnetic field will experience a force that is the vector sum of the electric and magnetic forces acting on the particle.
3. What is the significance of the velocity term in the force on a moving charge expression?
The velocity term in the force on a moving charge expression represents the effect of the magnetic field on the moving charge. This term takes into account the direction of the charge's motion relative to the magnetic field, and shows that the magnetic force is dependent on the charge's velocity.
4. How does the force on a moving charge expression change with an increase in the charge's speed?
The force on a moving charge expression does not change with an increase in the charge's speed. The force is solely dependent on the electric and magnetic fields and the charge's velocity, not the speed. As long as the charge's velocity remains constant, the force on the charge will also remain constant.
5. Can the force on a moving charge expression be used to determine the trajectory of a charged particle?
Yes, the force on a moving charge expression can be used to determine the trajectory of a charged particle. By using the principles of Newton's laws of motion, the force on a charged particle can be used to calculate its acceleration and therefore its trajectory in an electric and magnetic field.
