[Electromagnetism] How much work is required in moving Q3 to infinity?
In summary, the work required to move Q3 to infinity while Q1 and Q2 remain in their positions is approximately -1.0 J. This can be calculated by finding the change in potential energy (ΔPE) which is equal to the final potential energy (PEfinal) minus the initial potential energy (PEinitial). Using the formula PE=kQ1Q2/r, the final and initial potential energies can be calculated and the change in potential energy can be found.
Sean1218
86
How much work is required in moving Q3 to infinity while Q1 and Q2 remain in their positions?
Q3-------a-------|
|-----------------| b
Q1-------------Q2
a = 16.0 cm
b = 6.0 cm
Q1 = 5.70 μC
Q2 = -5.70 μC
Q3 = 1.8 μC
W=ΔPE
PE=kQ1Q2/r
Just added the potential energies associated with Q3 which is the work needed to move Q3 to infinity (i.e. bring said potential energies to 0).
kQ1Q3/r13 + kQ2Q3/r23
=(8.9875e9)(5.7e(-6))(1.80e(-6))/0.06 + (8.9875e9)(-5.7e(-6))(1.8e(-6))/sqrt(0.06^2 + 0.16^2)
=0.997 J
Also tried calculating ΔPE = final - initial (I think I messed up the formula, but somehow I got the negative of the first one)
(8.9875e9)(5.7e(-6))(-5.7e(-6))/.16 + 0.827790168702400828475759973771078927721678492943077184393)
= -0.997 J
Trying ΔPE again:
kQ1Q2/r12 - (kQ1Q3/r13 + kQ2Q3/r23 + kQ1Q2/r12)
=-kQ1Q3/r13 - kQ2Q3/r23
=-(8.9875e9)(5.7e(-6))(1.8e(-6))/0.06 - (8.9875e9)(-5.7e(-6))(1.8e(-6))/sqrt(0.06^2 + 0.16^2)
= -0.997 J
What am I supposed to do? Neither of these work.
Sean1218 said:
W=ΔPE
PE=kQ1Q2/r
Yes. And you realize ΔPE is PEfinal - PEinitial, right?
No, the work needed is ΔPE, which is PEfinal - PEinitial.
=0.997 J
You have calculated PEinitial here. You want PEfinal-PEinitial.
= -0.997 J
Trying ΔPE again:
= -0.997 J
Your second answer (the negative one) looks correct to me. However if I use a rounded-off version of k, 8.99e9 N*m2/C2, then the answer rounds off to -0.998 J.
p.s. please don't report results, even intermediate calculations, to 50 significant figures. It just clutters up your work unnecessarily for people who are trying to follow your calculation.
Are you submitting this to a computer? I'm not sure how many significant digits your answer should have, but have you tried -1.0?
Related to [Electromagnetism] How much work is required in moving Q3 to infinity?
1. What is the definition of work in the context of electromagnetism?
Work is the transfer of energy from one object to another by applying a force over a distance. In the context of electromagnetism, work is done when a charged particle is moved through an electric or magnetic field.
2. How is the amount of work calculated in moving a charged particle in an electric field?
The amount of work required to move a charged particle in an electric field is calculated by multiplying the magnitude of the electric field by the distance that the particle is moved. This can be represented by the equation W = qEd, where W is work, q is the charge of the particle, E is the electric field strength, and d is the distance moved.
3. What is the relationship between work and potential energy in an electric field?
In an electric field, work is done to move a charged particle from one point to another, which results in a change in potential energy. The potential energy of a charged particle in an electric field is given by the equation PE = qV, where PE is potential energy, q is the charge of the particle, and V is the potential difference between the two points.
4. How does the distance between the charged particle and the source of the electric field affect the amount of work required to move it?
The amount of work required to move a charged particle in an electric field is directly proportional to the distance between the particle and the source of the field. This means that as the distance increases, the amount of work required also increases.
5. Is the work required to move a charged particle to infinity in an electric field always the same?
No, the work required to move a charged particle to infinity in an electric field varies depending on the strength of the field and the charge of the particle. In general, the work required will increase as the electric field strength or the charge of the particle increases.
