johnaphun
- 14
Assuming the Poisson equation d2V = -p/e0
show that the electric field in a cavity is zero
(Explain clearly each step of your argument)
Here's my attempt (i think it's correct, (kind of) I'm just not sure if I've explained the argument clearly enough).
p = 0 inside the cavity as there is no charge contained within the volume. All excess charge resides on the surface therefore d2V = 0
As a result the E field inside the conductor is zero and gradV is also equal to zero meaning V = constant
V in the cavity is given by the solution to Laplace's equation subject to the b.c's that V is constant on the interior surface. Earnshaw's theorem dictates that V can not have either a minima or maxima inside the conductor only on the surface meaning V inside the cavity is constant which means E = 0
