291108
- 1
I am trying to conduct an investigation based on the set up of a set of copper coils with AC ran through them to make them an electromagnet. Held above them inplace is an aluminium plate. I know that the changing magnetic field induces a current in the aluminium plate, which induces a voltage and then a magnetic field which is out of phase with the electromagnet, and so an oposing force is made. I am measuring the force by having a sensitive set of scales under the coil which measures the change in force on the coil.
However i am trying to investigate the effects of changing the electromagnet
I have already tried
-different diameter of wire.
-Differnt radius of the coils
-Different number of coils.
-Changing the current through the coils.
I have already discovered (i think) that it is a squared relationship for increasing the current and force.
However is there an equation for this?
Also, what kind of relationship should i expect with the other factors and why?
How exactly would i calculate the force that results in the copper coils being pushed into the scales? Measuring the change in weight only really gives me a sort of qualatative answer.
any help would be much appreciated.
Thanks
Thanks
