Electromagnets and Conversation of Energy
In summary, the conversation discusses the concept of how running an electric current through a copper wire induces a magnetic field, and how wrapping the wire around a ferromagnetic material can amplify the field. It is noted that this does not violate the first law of thermodynamics because magnetic fields are local and do not permeate the entire universe. The conversation also hypothesizes that the difference in the strength of the magnetic field between a wire with and without a ferromagnetic core will be greater than the amount of work required to place the core in the wire. However, there is some confusion about the relevance of this information and how it relates to the situation.
treehouse
105
Running an electric current through a copper wire induces a magnetic field. Wrapping that wire around a ferromagnetic material amplifies its magnetic field (this is the basis on which electromagnets are designed*). This does not violate Newton's first law of thermodynamics because magnetic fields are local - the flux lines of a magnetic field do not permeate the entire universe.
I hypothesize that if the same voltage is run through the wire with and without the ferromagnetic core for long enough, the difference in the strength of the magnetic field will be greater than the amount of work required to place the core in the wire.
*http://en.wikipedia.org/wiki/Magnet...d_due_to_moving_charges_and_electric_currents
http://en.wikipedia.org/wiki/Electromagnet#History
Why do you say the lines don't permeate the whole Universe? They certainly can permeate a long way before getting mixed up with the fields due to other currents. Is it relevant to the situation? I'm not sure.
When you APPLY the voltage across (not "run it through") the coil, energy is transferred, as you say, as the current builds up. The Energy stored will be I^2 L/2 (where L is the inductance of the coil). The ferromagnetic core will produce more of a back emf, resulting in a smaller effective PD to cause the current to increase. As the current increases over a longer time so the integral of VdI over time will be greater with a core than without one.
(Just another of the many ways of looking at this sort of thing.)
I don't see why you are comparing the strength of a magnetic coil with and without an iron core to work done to place the core in the coil. Which isn't much unless it was already turned on. Work and force are not the same thing.
Related to Electromagnets and Conversation of Energy
1. What is an electromagnet?
An electromagnet is a type of magnet that is created by passing an electric current through a wire. The electric current creates a magnetic field around the wire, which can attract and repel other materials.
2. How does an electromagnet work?
When an electric current passes through a wire, it creates a magnetic field. The strength of this magnetic field can be increased by increasing the amount of electric current or by wrapping the wire into a coil. This creates a stronger magnetic force, making the electromagnet more powerful.
3. What is the conservation of energy?
The conservation of energy is a fundamental law of physics that states that energy cannot be created or destroyed, but can only be transformed from one form to another. In the case of electromagnets, the energy used to create the magnetic field comes from the electric current passing through the wire.
4. How is the conservation of energy related to electromagnets?
The conservation of energy is related to electromagnets because the energy used to create the magnetic field is converted into magnetic energy. When the electric current is turned off, the magnetic field collapses and the energy is released back into the circuit in the form of an electric current.
5. What are some real-world applications of electromagnets?
Electromagnets have a wide range of applications in our daily lives, such as in household appliances, electric motors, generators, MRI machines in hospitals, and even in transportation systems like trains. They are also used in industrial machinery, scientific equipment, and telecommunications devices.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
