Electromotive force in a moving bar
In summary, the bar has an emf between the 2 edges due to the magnetic field. The current will flow in the opposite direction to the field.
shaiyefet
Hi everyone,
I've seen in some lecture notes that a moving conducting bar (length of L) in a uniform and constant magnetic field develops an electromotive force (emf) between the 2 edges of the bar.
Lets assume that the bar moves to the right (with velocity v) and the magnetic field (B) points into the screen.
So the explanation I've seen is that the magnetic field applies force on positive charges towards one side of the bar and negative charges towards the other side.
The system comes to a steady state when the emf between the 2 edges of the bar is:
emf=L*v*B
So as long as the bar is moving there is emf.
So the bar is now like a battery, and if we'll connect a wire between the 2 edges of the bar to create a closed circuit then we'll have current flowing in the loop.
But since the magnetic field is constant and uniform and the circuit area does not change, then according to Faraday's law, the magnetic flux through the circuit area is constant, so there should be no emf...
Can anybody help me solve this??
Thanks a lot!
Shai
Make the loop square - there will be EMF in one "bar" of the loop - what about the opposite bar?
Yeah I see now,
So you mean that the opposite bar will develop the same emf, and will be considered as a second battery, so the 2 batteries facing each other, so no current will flow, right?
Please confirm just to be sure...
Thanks a lot...
Yep - by the "generating emf" description.
There's a bunch of puzzles like this... you can do it by rotating the loop so half moves one way and the other half moves the opposite way.
If the bar is resting on rails and the rails are connected by a fixed connector then a current will flow from the moving wire as it is pulled, along the rails, to the right.
If the field is into the screen as you quote then the top end of the moving wire will be +ve and the bottom end will be -ve
Related to Electromotive force in a moving bar
1. What is electromotive force (EMF)?
Electromotive force, also known as EMF, is the potential difference or voltage created by the motion of a conductor through a magnetic field. It is responsible for the production of electric current in generators and motors.
2. How is EMF generated in a moving bar?
EMF is generated in a moving bar when it cuts through the magnetic field lines. The movement of the bar creates a force that pushes the free electrons in the conductor, creating a potential difference between the two ends of the bar.
3. What is the relationship between EMF and velocity of the moving bar?
There is a direct relationship between EMF and the velocity of the moving bar. As the velocity of the bar increases, the EMF also increases. This is because the rate at which the bar cuts through the magnetic field increases, resulting in a greater EMF.
4. Can the direction of EMF be reversed in a moving bar?
Yes, the direction of EMF can be reversed in a moving bar by changing the direction of the magnetic field or the direction of motion of the bar. This will result in a change in the polarity of the potential difference created.
5. What are some practical applications of EMF in a moving bar?
EMF in a moving bar has numerous practical applications. It is used in generators to produce electricity, in motors to convert electrical energy into mechanical energy, and in devices like microphones and speakers to convert sound energy into electrical energy.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
