Electron accelerated by potential difference
In summary, if an electron is accelerated by a potential difference of 100V, its final speed would be doubled if it were accelerated with four times as much voltage. This is because the energy of the electron is directly proportional to the potential difference. So, if the potential difference is increased by a factor of 4, the energy and therefore the speed of the electron would increase by a factor of 4 as well.
gillgill
128
An electron is accelerated by a potential difference of, say, 100V. How much greater would its final speed be if it were accelerated with four times as much voltage?
The corresponding energy is eV where e is the elementary charge and v is the applied potential. Note that this energy is kinetic in nature and therefore equal to 1/2mv²
regards
marlon
Ep=Ek
eV=1/2mv²
so...four times as much voltage= 16 times greater speed?
So if the potential is 4 times bigger then the kinetic energy will get four times bigger. If A = mv²/2 or v = sqrt(2A/m) ; well then after the increase : 4A = mv²/2 or mv² =8A or v = sqrt(8a/m). Now if you divide sqrt(8A/m) by sqrt(2A/m) you acquire : sqrt(4) = 2. So the speed would be doubled...you see
regards
marlon
FAQ: Electron accelerated by potential difference
What is an electron?
An electron is a subatomic particle with a negative charge that orbits the nucleus of an atom.
What is potential difference?
Potential difference, also known as voltage, is the difference in electric potential energy between two points in an electric field.
How is an electron accelerated by potential difference?
When an electron is placed in an electric field with a potential difference, it experiences a force that accelerates it towards the positive end of the field.
What is the unit for potential difference?
Potential difference is measured in volts (V).
How does potential difference affect the speed of an accelerated electron?
The higher the potential difference, the greater the force on the electron and the faster it will accelerate. However, the speed of the electron will eventually reach a maximum as it approaches the speed of light.
