Electron and hole fermi surface-what does it mean?
In summary, the paragraph is discussing the concept of the Fermi surface and how it relates to the Hall coefficient in different scenarios.
lavster
217
hi i was reading the following paragraph and i do not understand what it means. can someone explain what it means to me please? i know what the individual concepts are eg fermi line, hall coefficeint extended zone schemes, but am not grasping the concept of the two types of fermi surface...
"For electron states contained within the fermi line in reduced or periodically extended zone schemes we have an electron fermi surface and a negative hall coefficient. For electron states contained outside the Fermi line in reduced or periodically extended zone schemes we have a hole fermi surface and a positive hall coefficient."
thanks
!This paragraph is talking about the Fermi surface, which is a surface in momentum space that separates the states that are occupied by electrons from the states that are unoccupied. The Fermi line is the line in momentum space that marks the boundary between the occupied and unoccupied states. If the electron states are contained within the Fermi line, then this means that the electrons are occupying all of the states below the Fermi line in momentum space. This is known as an electron Fermi surface, and it has a negative Hall coefficient. If the electron states are contained outside of the Fermi line, then this means that the electrons are occupying all of the states above the Fermi line in momentum space. This is known as a hole Fermi surface, and it has a positive Hall coefficient.
Related to Electron and hole fermi surface-what does it mean?
1. What is the Fermi surface in relation to electrons and holes?
The Fermi surface is a concept in solid state physics that describes the boundary in momentum space between filled and unfilled energy levels for a given material. In the case of electrons and holes, the Fermi surface represents the region in momentum space where the energy levels for both particles are equal.
2. How is the Fermi surface related to the Fermi energy?
The Fermi energy is the maximum energy that an electron in a solid can have at absolute zero temperature. It is directly related to the Fermi surface, as the Fermi energy is the energy level that separates the filled and unfilled states on the Fermi surface in momentum space.
3. What does it mean for a material to have a large or small Fermi surface?
A large Fermi surface means that there are many available energy states for particles to occupy, while a small Fermi surface indicates a more limited number of available states. This can have implications for the electrical and thermal conductivity of a material, as well as its magnetic properties.
4. How does the Fermi surface change with temperature and doping?
In a material with a fixed number of particles, the Fermi surface remains unchanged with temperature. However, it can change with doping, which is the introduction of impurities or defects into a material. This can alter the number of available energy states and thus change the shape and size of the Fermi surface.
5. Can the Fermi surface be measured experimentally?
Yes, the Fermi surface can be probed through various experimental techniques such as angle-resolved photoemission spectroscopy (ARPES) and de Haas-van Alphen (dHvA) effect. These methods provide information about the energy and momentum of particles in a material, allowing for the visualization and characterization of the Fermi surface.
  • Atomic and Condensed Matter
  • Quantum Physics
