Electron arrangement and ionisation energy
In summary, the higher energy level of p orbitals makes it easier to remove an electron from them compared to s orbitals, which have a lower energy level. This is because the total energy of an atom is negative and increases as you move down the energy level diagram. Therefore, it requires less energy to remove an electron from a p orbital than an s orbital, similar to how it is easier to pull water from a shallow well compared to a deeper one.
Gajan1234
46
Why is it easier to remove an electron from p orbital than s orbital. I thought P orbital have higher energy so more energy is require to remove a electron from P orbital.
look at the energy level diagram of any atom- the ground state is the lowest one and are usually l=0 i.e. s state -in chemistry people call it orbital.
higher than s is a p-state ,then d,e,f, etc are placed.
but atom is a bound state of electron with nucleus - a bound state has its total energy -ve otherwise the electron will be free.
So the diagram is like a well with energy values rising downward top most is E=0.
For example H-atom ground s =state is at -13.6 eV so all p,d states will be above this value
-less negative than the ground so it will be easier to take out an electron from a P-state rather than S-state.
just like it is easier to pull water from a shallow well rather than a deeper well. so less energy will be required for a p-state electron to get it to E=0 rather than a lower S-state which is deeper.
Likes entropy1 and Gajan1234
Related to Electron arrangement and ionisation energy
1. What is meant by electron arrangement?
Electron arrangement refers to the specific distribution of electrons in an atom's energy levels or orbitals. It determines the atom's chemical and physical properties and is responsible for the formation of chemical bonds.
2. How is electron arrangement related to ionisation energy?
Ionisation energy is the minimum amount of energy required to remove an electron from an atom. The electron arrangement of an atom determines its ionisation energy, as it reflects the stability of the atom and the strength of its attraction to its electrons.
3. What factors affect the electron arrangement of an atom?
The electron arrangement of an atom is influenced by the number of electrons, the number of energy levels, and the electron shielding effect from inner levels. Additionally, the type of element and its position on the periodic table can also affect electron arrangement.
4. How does ionisation energy change across a period on the periodic table?
Ionisation energy generally increases across a period on the periodic table. This is because as you move from left to right, the number of protons and electrons increases, leading to a stronger attraction between the nucleus and the outermost electrons. As a result, more energy is required to remove an electron.
5. Why does ionisation energy decrease down a group on the periodic table?
Ionisation energy decreases down a group on the periodic table because the outermost electrons are further away from the nucleus due to the addition of more energy levels. This leads to a weaker attraction between the nucleus and the outermost electrons, making it easier to remove an electron and resulting in a lower ionisation energy.
  • Chemistry
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
