Electron Capture - X-ray or gamma-ray?
In summary, electron capture transforms the nuclide into a new element. The atom, although still neutral in charge, now exists in an excited state with the inner shell missing an electron. An outer shell electron will eventually transition to fill the missing inner electron thereby dropping to a lower ground state. During this process, that electron will emit an X-ray photon (a type of electromagnetic radiation) and other electrons may also emit Auger electrons.
rwooduk
762
59
I may be being a bit pedantic but when an electron "falls" (or is captured by) into the nucleus, does the outer shell electron that fills its place result in an x-ray or a gamma-ray being emitted? Or would it depend on the energy transition?
Thanks for any ideas.
from Wiki ...
Since a proton is changed to a neutron during electron capture, the number of neutrons in the nucleus increases by 1, the number of protons decreases by 1, and the atomic mass number remains unchanged. By changing the number of protons, electron capture transforms the nuclide into a new element. The atom, although still neutral in charge, now exists in an excited state with the inner shell missing an electron. An outer shell electron will eventually transition to fill the missing inner electron thereby dropping to a lower ground state. During this process, that electron will emit an X-ray photon (a type of electromagnetic radiation) and other electrons may also emit Auger electrons. Often the nucleus exists in an excited state as well, and emits a gamma ray as it transitions to the ground state energy of the new nuclide.
does that answer you Q ?
Dave
Likes rwooduk
davenn said:
from Wiki ...
Dave
Hmm, sorry should have checked Wiki. Yes very helpful, thankyou!
no probs, you are welcome :smile:
Likes rwooduk
In general, keep in mind, that electron shell transitions don't produce gamma rays but X-rays... The transitions of nuclei are the ones producing gamma rays.
However, with artificial sources now able to duplicate any electromagnetic radiation that originates in the nucleus, as well as far higher energies, the wavelengths characteristic of radioactive gamma ray sources vs. other types, now completely overlap. Thus, gamma rays are now usually distinguished by their origin: X-rays are emitted by definition by electrons outside the nucleus, while gamma rays are emitted by the nucleus.
http://en.wikipedia.org/wiki/Gamma_ray
Likes rwooduk
That has its own problems. Thorium 229 has an excitation just 8 eV above the ground state, the corresponding "gamma ray" is in the ultraviolet range.
Exceptional things always exist... doesn't change the fact that the heavy atoms generally tend to emit in the X-rays (keV spectra), while nuclei in general tend to emit in the MeV ranges (gamma).
FAQ: Electron Capture - X-ray or gamma-ray?
What is electron capture and how does it produce X-rays or gamma-rays?
Electron capture is a type of nuclear decay process where an electron from an inner shell of an atom is absorbed into the nucleus. This results in the release of energy in the form of X-rays or gamma-rays.
What elements are most likely to undergo electron capture?
Elements with large atomic numbers, such as radium, uranium, and plutonium, are most likely to undergo electron capture. This is because they have a greater number of protons, making their nuclei more unstable and prone to electron capture.
How does electron capture differ from other forms of nuclear decay?
Electron capture differs from other forms of nuclear decay, such as alpha and beta decay, because it involves the absorption of an electron by the nucleus rather than the emission of particles. This results in a decrease in atomic number and a change in the energy level of the nucleus.
How is electron capture used in medical imaging?
Electron capture is used in medical imaging through the process of X-ray fluorescence. This involves targeting a specific element in the body, such as iodine, and using a radioactive isotope that undergoes electron capture to produce X-rays. These X-rays can then be detected and used to create images of the body's internal structures.
What are the potential hazards of electron capture in nuclear reactors?
Electron capture can be a potential hazard in nuclear reactors as it can lead to the buildup of radioactive elements and the release of harmful radiation. This is why safety protocols and containment systems are in place to prevent and manage electron capture reactions in nuclear reactors.
