Electron Configurations Phosphorus
  • Thread starter nobodyuknow
  • Tags
    Electron
In summary, the given electron configurations for Phosphorus are as follows: 1. 1s2 2s2 2p6 3s1 3p42. 1s3 2s3 2p6 3s2 3p13. 1s2 2s2 2p6 3s2 3p2 3d14. 1s2 2s2 2p6 3s2 2d1 3p25. 1s2 1p6 2s2 2p56. 1s2 2s2 2p6
nobodyuknow
64
Here are the following Electron Configurations of Phospohorus
5. 1s2 1p6 2s2 2p5
6. 1s2 2s2 2p6 3s2 3p3
Questions:
Which of these have non-existent orbitals?
Which of these violate Pauli's Principle?
Which of these are in the excited state?
Which of these are it's ground state?
. The attempt at a solution
Just double checking... since I want to get the full marks remaining for this question (got it wrong before, and it's allocated me a new element)
Non-Existent Orbitals
4 & 5, No such thing as 2d and 1p orbitals.
6 is its ground state
1 & 3 are excited states, (the 3s orbitals aren't totally filled?)
That leaves, 2, violating Pauli's principle, which honestly, I have no idea about.
Could someone confirm these for me and perhaps enlighten me more on these.
Thanks!
What does Pauli's principle say?
(check your notes, or book, or google, or check wikipedia if you don't know)
Pauli's Exclusion Principle...
each electron in an atom has a unique set of quantum numbers which must abide to a specific criteria...
where basically, any orbital can only contain a maximum of two electrons.
Ahh, when I actually bother to read my notes, I see that p-orbitals have 3 sub-orbitals and that s-orbitals contain 1.
So clearly, '2' violates Pauli's Exclusion Law.
However, in my notes, I see that I've got Quantum Numbers noted down, what exactly do these suggest? I can't seem to find my notes on these.
I don't see what you mean by
Note: name 'orbital' can be confusing, as it used to refer to both p (three suborbitals) and px (or py, pz) - which were just called suborbitals moment ago.
Basically, this 1s3 2s3 2p6 3s2 3p1 violates Pauli's Law because of the third electron in the 2s orbital.
And 1s3 is OK?
Related to Electron Configurations Phosphorus
What is the electron configuration of phosphorus?
The electron configuration of phosphorus is 1s2 2s2 2p6 3s2 3p3.
How many valence electrons does phosphorus have?
Phosphorus has 5 valence electrons.
Why is the electron configuration of phosphorus significant?
The electron configuration of phosphorus is significant because it determines the chemical and physical properties of the element. It also indicates the stability and reactivity of the atom.
What is the shorthand notation for the electron configuration of phosphorus?
The shorthand notation for the electron configuration of phosphorus is [Ne] 3s2 3p3.
How does the electron configuration of phosphorus relate to its position on the periodic table?
The electron configuration of phosphorus follows the periodic trend as it is located in group 15 of the periodic table. This means that it has 5 valence electrons and shares similar properties with other elements in the same group, such as nitrogen and arsenic.
90K
14K
  • Chemistry
25K
13K
  • Chemistry
14K
