Electron distribution using tight binding band structure?
In summary, calculating the electron distribution for a system like graphene or any other solid using tight binding band structure involves obtaining the tight binding band structure, using the Bloch sum to obtain the wave function for each band state, and then squaring and summing the wave function to get the electron distribution. The coefficients in the Bloch sum are the eigenvectors of the tight binding band structure, and for graphene, the wave function is a combination of the \pi orbitals of the carbon atoms.
radyab1297
Hi everyone,
I am just wondering how to calculate electron distribution using tight binding band structure for a system like graphene or any other solid.
So the goal is to get |\psi(r)|^2 which \psi is the band state and it is the linear combination of Bloch sum:
\psi={\sum_n,R}{c_nk}exp(ik.R){\phi(r-r_nR)}
c_nk is the eigenvector of the tight binding band structure that we already have them. n is the the orbital position in R unit cell and \phi is \pi orbital.
Thank you for your help in advance.
Hello,
Calculating the electron distribution using tight binding band structure for a system like graphene or any other solid involves a few steps. First, we need to obtain the tight binding band structure for the system, which can be done through various methods such as density functional theory (DFT) calculations or empirical tight binding models. Once we have the tight binding band structure, we can then use the Bloch sum to calculate the electron distribution.
The Bloch sum is a linear combination of the wave functions of the individual atoms in the unit cell, which are multiplied by a phase factor determined by the wave vector (k) and the lattice vector (R). This gives us the wave function (\psi) for a particular band state, which is a function of both position (r) and the band index (n).
To calculate the electron distribution, we need to square the magnitude of the wave function (\psi) and sum over all the occupied band states. This will give us the electron density at each point in the system.
In the case of graphene, the wave function (\psi) is a combination of the \pi orbitals of the carbon atoms in the unit cell. The coefficients (c_nk) in the Bloch sum are the eigenvectors of the tight binding band structure, which can be obtained from DFT calculations or other methods.
I hope this helps. Let me know if you have any further questions.
Related to Electron distribution using tight binding band structure?
1. What is tight binding band structure?
Tight binding band structure is a method used to describe the electronic structure of materials, specifically in solids. It takes into account the interactions between atoms and their valence electrons to determine the energy levels and distribution of electrons in a material.
2. How is the electron distribution calculated in tight binding band structure?
In tight binding band structure, the electron distribution is calculated by considering the overlap of atomic orbitals between neighboring atoms in a material. This overlap determines the energy levels and distribution of electrons in the material.
3. What factors affect the electron distribution in tight binding band structure?
The electron distribution in tight binding band structure is affected by several factors, including the type of material, the arrangement of atoms, and the strength of the interactions between atoms and their valence electrons.
4. What is the significance of electron distribution in tight binding band structure?
The electron distribution in tight binding band structure is significant because it determines many of the physical and chemical properties of a material. It can affect properties such as electrical conductivity, thermal conductivity, and optical properties.
5. Can tight binding band structure accurately predict the behavior of electrons in real materials?
Tight binding band structure is a simplified model and cannot fully capture all aspects of electron behavior in real materials. However, it can provide valuable insights and predictions about electronic properties, and with certain modifications, it can be used to accurately describe the behavior of electrons in specific materials.
  • Atomic and Condensed Matter
