Electron drift caused by a magnetic field gradient
In summary, at the equator, the Earth's magnetic field has a gradient of 3 times 10^-5 T which causes a velocity drift of 10^{-15} m/s.
eoghan
207
The magnetic field of the Earth it's approximately [itex]B=3\times10^{-5}T[/itex] at the equator and diminishes with the distance from the center of the Earth as [itex]1/r^3[/itex], as a dipole. Consider a population of electrons on the equatorial plane with energy 30keV, at 5 Earth radius from the center of the Earth.
Considering only the drift caused by the gradient of the magnetic field (i.e. ignore the curvature of the field lines) determine the velocity drift.
[tex]
v_d=-\frac{\epsilon_\bot}{B}\frac{\nabla B\times B}{qB^2}
[/tex]
Earth radius = 6371km
[tex]
|v_d| = \frac{3\times 10^4eV}{(3\times 10^{-5}T)^2}\frac{1}{(5\cdot6371\times10^3m)^3} \approx 10^{-15} m/s
[/tex]
Is this result correct? Because it seems to me to be too low...moreover the next question asks to compute how many time will take for the electron to go around the Earth circumference.
Thank you very much for your help
Your units do not match, the result cannot be right. I don't see how you got those values based on the formula.
Yes, I made an error, the energy in the numerator is not in eV, but in Joule, because in the formula there is
[tex]
\frac{\epsilon_\bot}{q}=\frac{3\times10^4eV}{e}=3\times10^4J
[/tex]
Are the units now correct?
Anyway, the result doesn't change
eV and Joule are both energies, you have to keep the conversion in mind but that is not the issue I meant: the fraction just does not give a velocity.
It's like answering a question for a velocity with "5m". 5m is not a velocity, it cannot be the right answer.
Your new formula has wrong units as well, an energy divided by a charge is not an energy.
Ok... I understand where I am wrong, I took as the gradient of [itex]B[/itex] the value [itex]1/r^3[/itex] which is not correct.
To find the gradient I would do like that. The B field has the form [itex]k/r^3[/itex], where [itex]k[/itex] is a constant. To find this constant I know that at the equator [itex]B_{eq}=k/r_{eq}^3=3\times 10^{-5}T[/itex].
So [itex]k=B_{eq}r_{eq}^3[/itex]. The gradient is thus [itex]\nabla B=-\frac{B_{eq}r_{eq}^3}{r^4}[/itex].
What do you think? Is this correct?
There is a factor 3 missing (the gradient is the derivative of the field strength), but apart from that it looks good.
Thank you very much for your help!
Related to Electron drift caused by a magnetic field gradient
1. What is electron drift caused by a magnetic field gradient?
Electron drift caused by a magnetic field gradient is a phenomenon in which electrons in a conducting material experience a force and move in a specific direction due to a change in the strength of a magnetic field. This change in the magnetic field is known as a gradient.
2. How does a magnetic field gradient affect electron movement?
A magnetic field gradient affects electron movement by exerting a force on the electrons, causing them to move in a specific direction. The strength of the force depends on the strength of the magnetic field gradient.
3. What causes a magnetic field gradient?
A magnetic field gradient can be caused by a change in the distance between two magnetic poles, a change in the strength of a magnetic field, or a change in the orientation of the magnetic field lines.
4. What are some real-life applications of electron drift caused by a magnetic field gradient?
This phenomenon has many practical applications, including in particle accelerators, magnetic resonance imaging (MRI) machines, and magnetic levitation trains.
5. How can electron drift caused by a magnetic field gradient be controlled?
Electron drift caused by a magnetic field gradient can be controlled by using different materials with varying conductivities, changing the strength and direction of the magnetic field, or by using devices such as magnetic lenses to manipulate the movement of electrons.
