Electron emits a photon that emits an electron
In summary, a photon with an energy of 2.856 eV is capable of kicking out an electron from the n=4 orbit of a hydrogen atom.
skate_nerd
176
This problem has a photon that was emitted by an electron orbiting a hydrogen atom that dropped from n=5 orbit to n=2. I need to find out, if this photon emitted an electron from the n=4 orbit of another hydrogen atom, what the k.e. of this electron would be.
1/λ=R(1/n_f^2-1/n_i^2)
E=hc/λ
not sure of what else i need
So far I found the wavelength using the first equation I listed, and then from this found the energy of the first emitted photon. I got 2.856 eV. I'm pretty sure I am supposed to use this information to find out what the k.e. of the electron that this photon emits is, but I am unsure of how to do that.
At first I thought maybe the energy of the photon was equal to the total energy of the electron, and so 2.856 eV=k.e.+rest energy of the electron, but this obviously didnt work (got a negative number for k.e.).
Im sure there's just some equation I am missing. If someone would fill me in that would be appreciated.
I think your are getting confused by the terminology. The photon does not emit an electron. Rather, it strikes another atom and the atom emits the electron.
You want to know if a photon, with an energy of 2.856 eV, is capable of kicking out an electron from the n=4 orbit of a hydrogen atom. How will you calculate the energy required?
Would the energy required be E=-13.6 eV * 1^2 / 4^2?
What do i do with that energy required though?
How this electron (n=4) is getting this amount of energy to be kicked out?
That's the negative of the energy required... emitting a negative amount of energy is equivalent to absorbing the same amount.
Compare the amount of energy required to what is available in the incoming photon.
So I am pretty sure that by compare it you mean the total energy of the electron is the difference between the energy required to kick it out and the total energy of the photon.
However, i am still somewhat stuck on finding out how to get the kinetic energy out of this. If i use the total E of the electron=the k.e. + the rest E, ill get a negative number when i solve for the kinetic energy
You're not creating an electron, just moving one. So the rest mass doesn't enter the picture (unless there's so much energy involved that the electron's speed will be a substantial fraction of c, and that won't be the case for a photon that originated in a small transition in a hydrogen atom).
Once enough energy has been supplied to remove the electron ("escape"), whatever is left over will end up as remaining KE for the electron.
Oh okay i think i understand now. Thanks guys
Related to Electron emits a photon that emits an electron
What is the concept of "electron emits a photon that emits an electron"?
The concept describes the emission of a photon by an electron, which then leads to the creation of a new electron.
How does this process occur?
The process occurs when an electron, which is a negatively charged particle, releases a photon, which is a packet of electromagnetic energy. This photon then interacts with another electron, causing it to be emitted.
What is the significance of this process in the field of physics?
This process is significant because it demonstrates the interaction between matter and energy, which is a fundamental concept in physics. It also helps to explain the behavior of electrons in various systems.
Can this process occur in different environments?
Yes, this process can occur in various environments, such as in atoms, molecules, and even in the vacuum of space. It is a fundamental process that is observed in many natural phenomena.
What are some real-life applications of this concept?
This concept has various applications, including in the fields of optics, electronics, and energy generation. It is also used in technologies such as lasers, solar cells, and electron microscopes.
