Electron frequency components during orbital tunneling
In summary: Also the energy of the initial state is not necassarily the energy of the final state, it can be higher or lower.In summary, the time-dependent potential in this scenario causes the wave function to evolve and the energy of the initial and final states may not be the same. This can be investigated through the Schrödinger equation or numerical integration.
jhonnyS
TL;DR Summary
what is the real time process for the wave function when an electron is living in a potential well, and an other is aproaching?
For example, we have this two potencial wells approaching, the electron is confined in one.
the final appearance will be like this:
THEN, if we know a wave packet is formed by many frequencies, but in a potencial well there are just few frequencies allowed, energy levels, so let's say, one frequency adapted to... the form of the potential.
In the point when the electron begins to overstep to the other potential, and the wave "don't know there is a well that will confine it later" so cannot mantain this unic frequency component because there were the posibility to extend indefinitely. NEEDs more frequencies to form a "wave packet" to contain itself BUT this frequencies, at same time, are not allowed for the part of wave function that remains confined in the initial potential well.
thank you
jhonnyS said:
Summary:: what is the real time process for the wave function when an electron is living in a potential well, and an other is aproaching?
thank you
I'm not sure whether this answers your question, but you have a time dependent potential here. At any time where the second well becomes non negligible you no longer have purely a single well wave function.
The time evolution of that wave function is just described by the schrodinger equation or equivalently the time evolution operator, you could investigate it with numerical integration.
Related to Electron frequency components during orbital tunneling
1. What is orbital tunneling?
Orbital tunneling is a quantum mechanical phenomenon in which an electron is able to pass through a potential barrier, such as an energy barrier or a physical barrier, due to its wave-like nature.
2. How does orbital tunneling occur?
Orbital tunneling occurs when the electron's wave function overlaps with the potential barrier, allowing it to pass through with a small probability. This is possible due to the uncertainty principle, which states that an electron's position and momentum cannot be known simultaneously.
3. What are electron frequency components?
Electron frequency components refer to the different frequencies at which electrons can exist in an atom's orbitals. These frequencies are related to the energy levels of the electrons and determine their behavior and interactions within the atom.
4. How do electron frequency components change during orbital tunneling?
During orbital tunneling, the electron's frequency components change as it passes through the potential barrier. This is because the electron's energy level changes as it moves from one side of the barrier to the other, causing its frequency components to shift.
5. What is the significance of studying electron frequency components during orbital tunneling?
Studying electron frequency components during orbital tunneling allows us to better understand the behavior of electrons in quantum systems and can have practical applications in fields such as nanotechnology and quantum computing. It also helps us to further our understanding of the fundamental principles of quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
