Electron in orbit of around a single proton
In summary, when calculating the kinetic energy of an electron orbiting a stationary hydrogen atom, we use Newton's second law and the known charges of the electron and proton. This leads to a negative value, which may seem counterintuitive, but is necessary due to the direction of the centripetal force provided by the electron's motion.
Ian Baughman
36
Today I was doing some reading and I came across this topic. If we have a stationary hydrogen atom with a single electron in orbit around the nucleus and want to calculate the kinetic energy of the electron we would take the following approach.
1) Using Newton's second law:
F = ma ⇒ FE = mac ⇒ k(q1q2)/r2 = mv2/r​
2) We know:
charge of the electron = -e = -1.602×10-19 and the charge of the proton = +e = 1.602×10-19
3) Now using equation in step 1:
-k(e2)/r = mv2 ⇒ -k(e2)/(2r)=(1/2)mv2
We know kinetic energy is suppose to be positive so why is it that it comes out negative in this case?
Towards the nucleus of the atom.
So FE provides the centripetal force. It's the only force around. ##mv^2\over r## also points towards the center, so it needs a minus sign too.
Likes Ian Baughman
Related to Electron in orbit of around a single proton
1. What is the role of electrons in atoms?
Electrons are negatively charged particles that orbit around the positively charged nucleus of an atom. They play a crucial role in determining the chemical and physical properties of an element.
2. How does an electron orbit around a single proton?
Electrons follow a specific path or orbit around the nucleus of an atom due to the attraction between the positively charged proton and the negatively charged electron. This orbit is determined by the energy level of the electron.
3. What is the relationship between an electron's energy and its distance from the nucleus?
An electron's energy increases as its distance from the nucleus increases. This means that electrons in outer energy levels have higher energy levels than those in inner levels.
4. Why do electrons not spiral into the nucleus?
Electrons do not spiral into the nucleus because they possess angular momentum and are constantly moving, creating a balance between the attractive force of the proton and the centrifugal force of the electron's movement.
5. Can the orbit of an electron be precisely determined?
No, according to Heisenberg's Uncertainty Principle, it is impossible to determine both the position and momentum of an electron simultaneously. Therefore, the exact orbit of an electron cannot be determined.
  • Electromagnetism
