kahunah
- 10
A magnetic field of 0.0200 T (up) is created in a region
a. Find the initial magnetic force on an electron initially moved at 5.00 x 10^6 m/s [N] in the field
b. What is the radius of the circular path? Make a sketch showing the path of the electron.
Fm = q v b sinΘ
Fc = (m v^2)/r
a.
F_M=q v β
F_M=(1.6*10^(-19) C)(5.00*10^6 m/s)(0.00200 T)
F_M=1.6*10^(-15) N
my issue is the direction of the force. how do you apply the right hand rule to a charged particle moving in the same direction as the field? doesn't the particle need to travel perpendicular to the field to interact with it? because it's an electron i know i have to reverse it or use the "left hand rule" but I'm still utterly confused since the particle is moving in the same direction as the field.
b.
Fnet = Fm
in circular motion Fnet = Fc
Fc = Fm
(m v^2)/r = q v β
r = m v/q β
r = (9.1 * 1^-31 kg)(5.00 x 10^6 m/s)/(1.6 x 10^-19 C)(0.00200 T)
r = 0.142 m
r = 14.2 cm
