Electron orbital angular momentum
In summary, the ground state of an electron in a coulomb field must have the same symmetry as the potential, and the first excited state must have l=0,1 but not higher. The second excited state may have l=0,1,2 etc.
ijustlost
Why can't an electron in a coulomb field have an orbital angular momentum quantum number higher than it's principal quantum number (ie there is no 1p state etc.)
I think is probably something I learned at one point, but I've forgotten and can't seem to find anything about it anywhere. I know that it's a consequence of solving the radial Schrodinger equation, but I'd like to figure out why this should be, at least in vague terms.
"vague terms", huh? I'll give it my best shot:
the ground state must have the same symmetry as the potential, thus the ground state must be spherically symmetric, thus [itex]\ell=0[/itex].
Cheers, that makes sense. But why then may the first excited state have l=0,1 but not higher, the 2nd excited state have l=0,1,2 etc. I'm guessing the higher the energy the more the state may 'break' the symmetry of the potential.
And also in a nuclear potential there isn't any such restriction (ie there are 1p, 1d, 1f states etc), but the nuclear potential is spherically symmetric. Why is this?
I don't know if this is the best line of reasoning to continue--I was just giving you a cute, vague reason why the ground state should have l=0. I think that the only real way to understand the behavior of the quantum numbers really is through the analysis of the solutions to the differential equation to which they are solutions. I.e., in order for the solutions to be normalizable (physical), the quantum number l must be leq to the quantum number n. Remember, when you solve for the bound states you try a power series ansatz and get a condition on n and l in order to make the series finite...
Is it? I think the nuclear potential is a pleasant fiction
Why is this?
The nuclear problem is a many body problem with unknown "potentials". It's quite a bit different than the hydrogen atom... It's funny that a shell model works at all...
Well if you solve schrodinger equation factorizing the solution (as usual for a PDE) you can find the solution using Fouier tools (series, orthonormal sets...) whence you have found the coefficients you see how they are related... there are many books that make this calculation... i did it once it took me two days to get every minus or plus sign...
So... good work... take the tables of the laplacian in spherical coordinates and... blah bla bla...
ciao
In the pre-QM Bohr-Sommerfeld model, the electron has an elliptical orbit, in general. Orbits with different ellipticities have different amounts of orbital angular momentum, for the same energy. Zero angular momentum corresponds to an "orbit" that is actually a straight line passing through the nucleus. The maximum angular momentum for a classical orbit in general, is for a circular orbit.
I'm in a hurry right now and don't have time to work this out, but I wouldn't be surprised to find that the maximum value of the orbital quantum number corresponds to a circular orbit in the Bohr-Sommerfeld model, or at least nearly a circular orbit, in the limit of large values of n (energy level). It clearly wouldn't work for the ground state, in which the orbital angular momentum is zero.
And of course we know the Bohr-Sommerfeld model is ultimately wrong, so it's dangerous to make analogies using it...
The issue is much the same as throwing out the harmonic oscillator solutions that go as exp(+r^^2). Change the sign, and we get the normal solutions of Hermite Functions.
ijustlost -That is, this is a very standard problem in differential equations. To see what's going on, use the standard approach of factoring out the behavior at 0 and infinity, and then go for a power series solution. It will all become clear.
jtbell -- Interesting approach. Very likely will work OK for large n, the principle quantum number.
Regards,
Reilly Atkinson
reilly - I understand how it comes from solving the equations, I was just wondering if there was a nice 'classical' picture, but I guess there isn't really one that isn't terribly inaccurate.
jtbell - yeah makes sense
FAQ: Electron orbital angular momentum
What is electron orbital angular momentum?
Electron orbital angular momentum is a physical quantity that describes the rotation and orientation of an electron as it orbits around the nucleus of an atom.
How is electron orbital angular momentum related to the electron's energy level?
The electron's orbital angular momentum is directly related to its energy level. Higher energy levels correspond to larger orbital angular momentum values.
What factors affect the electron's orbital angular momentum?
The electron's orbital angular momentum is affected by the shape and size of the orbit, as well as the direction and speed of the electron's motion.
How is electron orbital angular momentum quantized?
Electron orbital angular momentum is quantized, meaning it can only take on certain discrete values. This is due to the wave-like behavior of electrons and their confinement to specific energy levels in an atom.
How does electron orbital angular momentum contribute to an atom's properties?
The electron's orbital angular momentum plays a crucial role in determining an atom's chemical and physical properties. It affects the atom's magnetic behavior, as well as its ability to interact with other atoms and molecules.
