Electron orbital the earth will radiate?
In summary: Let's clear some stuff up first. The principle of equivalence says that free fall is locally equivalent to inertial movement. It also says that being at rest in a static gravitational field (meaning following orbits of the time translation symmetry) is locally equivalent to acceleration. All these things presuppose that the system one is working with is local in space-time. An electron carries an electromagnetic field which fails to satisfy this requirement so the equivalence principle does not apply here.
magnetar
83
If an electron orbital the Earth only influence by gravity,does it emit electromagnetic waves? if so, the radius will decay,eventually falling on earth?
I have no idea what you mean by "an electric orbital the Earth only". Are you postulating an electron orbiting the earth? Why bother with such a strange example? Using the "planetary model", an electron orbiting the nucleus of an atom is accelerating and so must be emitting waves- which would result in its losing energy until it cannot orbit the nucleus. That is one of the things that led to the development of quantum physics. The "planetary model" is invalid and an electron emits electromagnetic waves only when goes from one "energy level" to another.
Quantum theory approaches classical theory for large quantum numbers. An electron orbiting Earth by gravity alone is on an orbit with a large quantum number. Therefore it has a large number of lower energy levels, and can and will emit electromagnetic waves as it goes to lower energy levels.
The relativistic problem is whether an electron held stationary in a field of gravity would be emitting electromagnetic waves?
It would not.
Sorry, the original problem was relativistic after all.
Principle of equivalence says that free fall has to be indistinguishable from inertial movement.
Since a charge carrier moving in a straight line does not radiate, is a charge carrier in free fall allowed to radiate?
Related to Electron orbital the earth will radiate?
1. What is an electron orbital?
An electron orbital is a region in space around an atomic nucleus where an electron is most likely to be found. It is often described as a "cloud" or "shell" that surrounds the nucleus.
2. How does an electron orbital relate to the earth?
An electron orbital does not directly relate to the earth. However, the earth is made up of atoms, and all atoms contain electrons in orbitals. The energy levels of these electrons contribute to the properties of the materials that make up the earth.
3. How does the earth radiate energy from electron orbitals?
Electrons in orbitals can transition between energy levels, releasing energy in the form of electromagnetic radiation. This radiation can manifest as light, heat, or other forms of energy. The energy radiated by the earth's electron orbitals contributes to the planet's overall energy balance and plays a role in processes such as the greenhouse effect.
4. Can electron orbitals change over time?
Yes, electron orbitals can change over time. The behavior of electrons in orbitals is governed by the laws of quantum mechanics, and they can transition between different energy levels or even occupy different orbitals under certain conditions.
5. Why is understanding electron orbitals important in science?
Understanding electron orbitals is crucial in many areas of science, including chemistry, physics, and materials science. It allows scientists to predict and explain the properties and behaviors of atoms and molecules, which in turn, helps us better understand the world around us.
