Electron orbitals of iron and copper
In summary, the electron orbitals of iron are 1s 2, 2s 2, 2p 6, 3s 2, 3p 6, 4s 2, 3d 6, and those of copper are 1s 2, 2s 2, 2p 6, 3s 2, 3p 6, 4s 1, 3d 10. The s orbital of iron is full while copper's is not. The d orbital of copper is full while the s (of iron) one is not. The effective nuclear charge seen by the d-electrons increases with increasing filling of the d-shell, resulting in the d shell becoming more and more stabilized when the number of d-electrons increases.
Johnleprekan
57
I was reading an article about the electron orbitals of iron and copper:
The electronic configuration of iron is 1s 2, 2s 2, 2p 6, 3s 2, 3p 6, 4s 2, 3d 6
And that of copper is 1s 2, 2s 2, 2p 6, 3s 2, 3p 6, 4s 1, 3d 10
Iron has an incompletely filled d orbital while copper has a full d orbital. The s orbital of iron is full while copper is not. Why is the d orbital of copper full when the s (of copper) one isn't? (s orbitals being able to hold two electrons that is) Why doesn't the s orbital fill up and leave the d orbital incomplete?
Chemistry news on Phys.org
Order in which orbitals are filled depends on the energy - the lower the energy of the atom, the more stable the configuration. Energies of these orbitals are almost identical, and some very tiny effects (like pairing or not pairing spins on a particular orbital) make one of the configurations slightly more stable. These differences are typically so small they require quite elaborate models to be reproduced.
You can also see an explanation saying that there is an additional energy gain in the case of half filled or full filled d orbital which makes d5 and d10 particularly stable. As far as I am aware it is not entirely true, even if we do observe d5 and d10 quite often. But I am not going into details, as it is not a subject I feel comfortable with.
Because it is more favorable (in terms of energy) to have a filled 3d and a partially filled 4s than the other way around. Why that is is much more complicated to answer. Check the following thread for more information: https://www.physicsforums.com/showthread.php?t=712360
There is an empirical set of rules, called the Slater rules
http://en.wikipedia.org/wiki/Slater's_rules
, to estimate the effective nuclear charge seen by electrons in the different sub-shells.
The effective nuclear charge seen by the d-electrons increases with increasing filling of the d-shell resulting in the d shell becoming more and more stabilized when the number of d-electrons increases.
This is understandable, as electrons in the same sub shell are not very efficient in screening each other from the nuclear charge.
Hence the energetic stabilization of the d-shell has two maxima at d5 and d10 respectively, as at going from d5 to d6 an electron has to be put into an orbital which contains already an electron, which is not as favourable as putting an electron into an empty orbital.
Delete please.
Related to Electron orbitals of iron and copper
1. What are electron orbitals?
Electron orbitals are regions of space surrounding an atomic nucleus where electrons are most likely to be found. They describe the energy and position of an electron within an atom.
2. How many electron orbitals does iron have?
Iron has four electron orbitals, which are named s, p, d, and f. These orbitals can hold a maximum of 2, 6, 10, and 14 electrons, respectively.
3. What is the electron configuration of copper?
The electron configuration of copper is 1s2 2s2 2p6 3s2 3p6 4s1 3d10. This means that copper has a total of 29 electrons, with one electron in the 4s orbital and ten electrons in the 3d orbital.
4. Why do iron and copper have different electron configurations?
The electron configuration of an atom is determined by the number of protons in its nucleus. Iron has 26 protons, while copper has 29 protons. This difference in the number of protons results in a different arrangement of electrons in the orbitals.
5. What is the significance of electron orbitals in iron and copper?
The electron orbitals in iron and copper play a crucial role in determining the chemical and physical properties of these elements. The arrangement of electrons in the orbitals affects their reactivity, conductivity, and magnetic properties, among others.
  • Chemistry
  • Other Physics Topics
  • Quantum Physics
