I Electron-Positron Pair Instability Supernova
The formation of electron-positron pairs during a supernova leads to increased energy density and a softening of the equation of state (EOS) by reducing internal radiation pressure. When high-energy gamma rays collide with atomic nuclei, they can produce these pairs, which contributes to instability in supermassive stars. As the energy density rises, the adiabatic index drops below 4/3, indicating a softer EOS that allows for easier compression of the star's material. This softening results in smaller radii for the stars, as they resist gravitational collapse less effectively. Ultimately, the interplay between pair production and energy density is crucial in understanding the dynamics of pair-instability supernovae.
debs1
How does the formation of electron positron pairs increase the energy density and softens the EOS?
I trrying to understand the pair instability supernova. In many texts and articles, it is written that the formation of electron positron pairs lead to instability, the energy density is increased and the adiabatic index drops below 4/3 which softens the equation of state.
  • How does the formation of electron positron pairs lead to instability?
  • How is the energy density increased?
  • What does it mean by 'softening of EOS' and how does it happen?
Ref:
1) https://ui.adsabs.harvard.edu/abs/1967ApJ...148..803R/abstract
2)https://arxiv.org/abs/1910.12874
3)https://arxiv.org/abs/2007.07889
Astronomy news on Phys.org
:welcome:
Wherever this gets moved to, you'll need some references for where you've been reading this stuff.
PeroK said:
:welcome:
I have included some references
The best statement I can readily find states "A stiff equation of state tends to have larger pressure for a given density. This material resists compression and these stars have larger radii. Naturally, a soft equation of state has smaller pressures, is more easily compressed, and produces stars with smaller radii."
The threshold for pair production is 1.022 MeV. A photon of that or greater theshold would produce an electron-proton pair and transform photon energy into rest mass + some kinetic energy, where the kinetic energy would be given by the difference in the total photon energy before and rest energy after. Then shortly thereafter, the positron would find an electron and annihilate, which would produce 2 photons of 0.511 MeV.
Energy density would increase during the collapse, or as the radius decreases?
Did the questions arise from the following article, which cites Ref 1?
https://en.wikipedia.org/wiki/Pair-instability_supernova
the production of free electrons and positrons in the collision between atomic nuclei and energetic gamma rays, temporarily reduces the internal radiation pressure supporting a supermassive star's core against gravitational collapse.
https://en.wikipedia.org/wiki/Pair-instability_supernova#cite_note-1
From the article,
In very massive, hot stars with interior temperatures above about 300000000 K (3×108 K), photons produced in the stellar core are primarily in the form of very high energy-level gamma rays. The pressure from these gamma rays fleeing outward from the core helps to hold up the upper layers of the star against the inward pull of gravity. If the level of gamma rays (the energy density) is reduced, then the outer layers of the star will begin to collapse inwards.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
