Electron vector analysis question
In summary, the author provides a summary of content and provides a solution to a problem without providing any information about trigonometry or geometry.
chemboy
3 electrons q1, q2, q3 setup in a right angled triangle
q1
q3-q2
charges are
q1 = +2.5 X 10^-17C
q2 = +3.0 X 10^-17C
q3 = +3.5 X 10^-17C
distances between the charges
q1-q3 = .03 m
q1-q2 = .05 m
setup FBD
\ 2F1
/ 3F1
q1
2F1 = k*q1*q2 / .05^2
= 2.7 X 10^-21N
3F1 = k*q3*q1 / .03^2
= 8.75 X 10^-21N
now I think I use cosine law to figure this out
Fnet = sqrt(2F1^2 + 3F1^2 - 2(2F1)(3F1)cos135)
= 7.1 X 10^-21
with all charges being positive, all qs are experiencing repulsion so the direction is away from q1
the question "calculate the magnitude and direction of force on q1"
To calculate the magnitude and direction of force on q1, find the force due to q3 on q1 and force due to q2 on q1. Find the resultant of these forces. Find the cosine of angle between these forces. It is not cos135. The direction of the resultant is given by angle made by the resultant with one of the forces.
well, I believe I have found the forces acting on q1 (by q2 and q3). I guess my problem is I don't know what to do next. From the example I am given in the text they used cosine rule and a FBD to calculate the resultant of these forces. I am guessing my problem is my Trig is rusty...
how do I determine what theta should be? (in the book they use an isosceles and use 120degrees in this example its a right angle triangle).
You have a right angled triangle and you know the length of two sides. That is all the information you need to calculate anything about that triangle. Can you remember the trigonometric ratios for a right angled triangle?
sin0 = opp/hyp
sin^-1(.03/.05) = 36.8 = 37 degrees
You don't have the opposite, you have the adjacent.
Fnet = sqrt(2F1^2 + 3F1^2 - 2(2F1)(3F1)cos37)
I really need to touch up on my trig before I go back to school
The net force will be the vector sum or resultant of the two vectors.
sorry I am lost here, unfortunately the book provided for this distance ed course is poorly written and the examples provided don't really help with answering of questions.
what in the trig am I messing up??
seeing as this is based on the original distribution of forces, I am asuming I am working with the right angled triangle.
Im trying to figure out theta for the upper left portion of this triangle (it probably has a name but I havnt touched trig in 10+ years). when looking for theta in this region, the triangle is setup as
| = A
\ = H
__ = O
q1 - q3 = A = .03m
q1 - q2 = H = .05m
given this information and the little trig I know, I can use cosine rule to solve for theta
where cos = A/H
cos^-1 (.03/.05) = 53 Degrees
am I then using
Fnet = sqrt(2F1^2 + 3F1^2 - 2(2F1)(3F1)cos53)
Its absolutely absurd that I have nobody through the distance education program to ask questions and I am left to throw my self at the mercy of the internet forums.
Thanks for any guidance
Its just the final part of adding the forces now that you're not doing correctly. You're going to have to set up a coordinate system and find the components of each vector along each of the axes. The following page may help you with that.
http://hyperphysics.phy-astr.gsu.edu/hbase/vect.html
so is this where I draw the FBD??
and I guess I will need to know the angles of the other vectors
so
q1 - q2 = 53
q3 - q1 = 90
q2 - q3 = 180 - (53 + 90) = 37
and
= 2.7 X 10^-21N
= 8.75 X 10^-21N
2F3 = k*q2*q3 / .04^2
=5.9 X 10^-21 N
So with all this information I should be able to answer the question?
the reason I keep going back to this
Fnet = sqrt(2F1^2 + 3F1^2 - 2(2F1)(3F1)cos0)
is because that's how they answered the question in the text (solving trignometrically using cosine rule with the FBD)
I get what you're doing now sorry. Its not often one uses the cosine rule to find resultant vectors. So you have the angle between the vectors with both starting from the same point. You need to find the angle between the vectors if you draw a diagram following the triangle law for addition of vectors. I take it you're familiar with that law if you're using the cosine rule to get the magnitude of resultant vectors. The other angle you worked out will help you.
Related to Electron vector analysis question
1. What is electron vector analysis?
Electron vector analysis is a method used in scientific research to study the properties and behavior of electrons. It involves the use of mathematical vectors to describe the motion and interactions of electrons in a system.
2. How is electron vector analysis different from other methods of electron analysis?
Electron vector analysis is different from other methods, such as energy dispersive X-ray spectroscopy or scanning electron microscopy, because it focuses specifically on the vector properties of electrons rather than their energy or physical structure.
3. What types of systems can be studied using electron vector analysis?
Electron vector analysis can be applied to a wide range of systems, including atoms, molecules, crystals, and materials. It is particularly useful for studying the electronic structure and properties of these systems.
4. What techniques are used in electron vector analysis?
The techniques used in electron vector analysis include computational simulations, mathematical modeling, and experimental measurements using instruments such as scanning tunneling microscopes or transmission electron microscopes.
5. What are some potential applications of electron vector analysis?
Electron vector analysis has many potential applications, including in materials science, nanotechnology, and quantum computing. It can also be used to study the electronic properties of biological molecules and to understand the behavior of electrons in extreme conditions, such as in high magnetic fields or at very low temperatures.
9K
9K
12K
