Electronic enclosure - Long screw holes
  • Thread starter Thread starter sengalraja
    Assembly enclosure
The discussion focuses on designing an electronic enclosure for a medical device that meets IP62 certification while addressing assembly challenges. The enclosure consists of two halves, with the bottom half being 200mm deep and the top half 50mm deep, requiring screws to be mounted from the bottom. Concerns include the risk of screws falling or getting stuck during assembly, which could increase production time. Suggestions include using female threaded extensions, captive screws, or turning the product upside down for easier screw insertion. The enclosure is made from polyurethane, and sealing screws with O-rings were also mentioned as a potential solution.
sengalraja
TL;DR Summary
Have long screw holes-affects assembly of enclosure
Hi,
I am designing an electronic enclosure for a medical device. For assembly reasons, the enclosure is split into two halves, with the bottom half having a depth of 200mm and the top half a depth of 50mm. I want the enclosure to be certified for IP62, hence I want the screw to be mounted from the bottom, so the screw holes are not exposed from the top. The issue I am faced is that I would have to move the screwdriver over a length of 200mm, to mount it onto the corresponding threaded insert in the top cover. There will be risks of screws falling off or getting stuck and the assembly time increase due to this step. I have ten screws to be mounted and this is going to be a major problem when we productise this. I can't seem to find any solution that will help solve the assembly issue while still keeping my other requirements intact.
Thanks
Instead of screw holes, can't you put female threaded extensions inside, reaching your thin bottom cover?
Captive screws, held in the holes before the two halves are put together?
What material are you making the enclosure out of?
We are making it out of polyurethane
Magnetized screwdriver.
OR​
Turn the product over before inserting the screws. This would let you drop the screws into the holes and then insert screwdriver and tighten.
(Philips head screws of course.)
If the product can used 'upside-down', consider sealing screws, these have an O-ring pre-installed under the head. (Ahh, never mind, I see IP64 is any-orientation water entry protection.)
Cheers,
Tom
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
