Electronic Steam Tables Programs
In summary, Electronic Steam Tables Programs are computer software that provide a comprehensive collection of thermodynamic and transport properties of water and steam at different temperatures and pressures. These programs are commonly used in engineering and scientific fields for calculations and analysis related to power generation, refrigeration, and heating systems. They offer a user-friendly interface and allow for quick and accurate retrieval of data, saving time and effort in manual calculations. Electronic steam tables programs are continuously updated and improved to provide the most accurate and reliable data for various applications. They are an essential tool for professionals working with steam and water properties.
naggy
60
Hi all,
Been a while since I posted in these forums. Looking for advice on steam table software package.
I am looking for a relatively simple software package to look up steam properties. Preferably compatible with Excel. It at least has to be able to compute
  • SH steam enthalpy as a function of steam temperature and pressure
  • Saturation temperature as a function of pressure
  • Density of SH steam as a function of steam temperature and pressure
  • Saturation pressure as a function of temperature
During my online search, I found this
http://www.steamtablesonline.com/
Does anyone have experience with this software package? What are you using for steam tables and thermodynamics properties of materials.
I use 'coolprop', an excel addin, simple and works well.
Looks like the excel add-in only includes a limited amount of the function library. Or am I missing something? Do I need anything except for the excel add-in files?
iirc the limitations are mainly that the add in can't do mixtures. If you are only interested in water it should be fine.
Related to Electronic Steam Tables Programs
1. How do electronic steam tables programs work?
Electronic steam tables programs use mathematical equations and algorithms to calculate the thermodynamic properties of water and steam, such as temperature, pressure, enthalpy, and entropy. These programs use these calculations to generate tables and graphs of steam properties.
2. What are the benefits of using electronic steam tables programs?
Electronic steam tables programs provide accurate and reliable data on steam properties, making it easier for engineers and scientists to design and analyze steam systems. They also save time and effort compared to manually calculating steam properties.
3. Can electronic steam tables programs be used for different types of steam?
Yes, most electronic steam tables programs can be used for both saturated and superheated steam. Some programs may also have the option to include different gases, such as air and carbon dioxide, in the calculations.
4. How do I know which electronic steam tables program to use?
It is important to choose an electronic steam tables program that is appropriate for your specific needs and applications. Consider factors such as accuracy, user-friendliness, and compatibility with other software or systems.
5. Are electronic steam tables programs reliable?
Yes, electronic steam tables programs are generally reliable as they use standardized equations and data from trusted sources. However, it is important to ensure that the program is up-to-date and that the data being used is accurate.
  • Mechanical Engineering
