dmriser
- 50
Hello,
I am designing a solar powered rc plane as a project. I have an electric motor assembly intended to be used with an 11.1 volt battery. My solar array outputs around a steady 7.5 volts. When configured with a battery the motor drew around 9-10amps of current under full load. Making the output around 111 watts of power. What strength of current would I need the solar array to output to achieve this power? And would this even work? I have calculated around 20amps (approximate). This is far above the output of my solar array in terms of current.
Also, how could I measure the maximum current my battery can supply if I want to include one. I assume that because of the thickness of the wires and other parameters my battery cannot give an infinitely strong current and deplete it's power almost immediately.. But how would
I measure it's peak current outflow? I hope I have asked these questions in a clear manner and some one may be able to give me some information. This is not homework, just for fun and knowledge. Thank you.
