medwatt
- 123
Hello,
I want to know what factors determine that a signal (radio wave, microwave, infra red) cannot be use for broadcasting but only point to point communication. I know that it has to do with frequency and the energy associated with it but cannot seem to have a concrete reason because of those in the microwave range.
For example I know that infra red which has highest frequency of the other two mentioned is only utilised in point to point communication as they cannot pass through walls and so it cannot be transmitted uni directionally.
Microwaves which start from 2 GHz can sometimes be used for broadcasting as in the case of FM or Television where the signals can penetrate through walls and at the same time for point to point between communication towers. Why then when considering the ku band ground station antennas send microwave signals to satellites which are in geostationary orbit using point to point communication (12GHz) and the satellite can then broadcast at 11GHz.
I really want to know the demarcation line where broadcasting is no longer an option but point to point !
Thank You
Thank You
